Boosted 5.slower - Page 3
LinkBack (3) Thread Tools
Old May 24th, 2010, 09:20 AM   #41
99FiveOh's Avatar
1999 Mustang
99FiveOh is on a distinguished road
I just had my old S/C car tuned at the dyno, after that the tuner said I could just sell the BTM because it wasn't necessary anymore.
1999 V6 Vert converted to 5.0 EFI with Vortech V2 SQ, Edelbrock Performer intake, BBK shorties, O/R H, Flowmasters, 42lb injectors, 75mm Pro-M with MAFia extender, 255lph fuel pump. SCT tuned 370 rwhp 400 rwtq.
Old May 24th, 2010, 03:25 PM   #42
95 & 97 GT
4.slo? is on a distinguished road
What is the difference between a blow through MAF?
<img src=http://i676.photobucket.com/albums/vv122/ralvarez26/splogoub7.gif border=0 alt= />
97gt Pi swapped, sreamin demon coils, taylor wires, diablo chip, cai, 3.73s. 9.3 in 1/8 with no traction.
Boosted 95GT under construction.
Old May 24th, 2010, 03:39 PM   #43
1994 Mustang GT vert
redturbo5.0 is on a distinguished road
The blow thru meters the air after the turbo and fits perfect with the intercooler pipes. A draw thru is mounted b4 the turbo. google it. i think i found a good web page just about it
Old May 24th, 2010, 11:56 PM   #44
95 & 97 GT
Ok thanks.
Old May 26th, 2010, 01:35 PM   #45
how much for it shipped to 78414 area code pm me
Old June 1st, 2010, 08:20 PM   #46
1995greengts is on a distinguished road
I installed this kitonmy car back in march. if anyone has any questions feel free to ask.
Old June 2nd, 2010, 11:50 AM   #47
Have you gotten it tuned? If so what are you using? I've been checking out quarter horse and binary editor. Anyone used this before?
Old August 8th, 2010, 11:50 PM   #48
95 & 97 GT
Finally got my car started after a long 2 1/2yr project, and sounded really good for about 3minutes, then it died! Found 4bent pushrods, summit sent me the wrong timing chain, the cam bolt was rubbing on the timing cover then somehow the bolt backed out and timing gear backed off and bent cam dowel pin. Really sucks, thinking about just finding a 351w.
Old August 9th, 2010, 09:31 PM   #49
1994 mustang gt vert
n/a
autoarc94 is on a distinguished road
sorry to hear about the 4 bent pushrods, i've been there, i got a dss block and the builder never put the cam bolt in, in the first place, made it about 2000 miles and it backed off, i didn't know until i pulled the timing cover and pan and still never found a bolt, only sheared pin...... but nonetheless, with your pan in the vert, did you have any clearance issues with the xbrace underneath, i've got a moroso and haven't tried yet because its not easy for me to get a cherry picker.......
thanks in advance and good luck with the car!
Old August 11th, 2010, 12:32 AM   #50
95 & 97 GT
I didn't have a problem with the pan, previous owner removed the brace I guess. Well I performed a leakdown test on all 8cylinders and at only 11psi the gauge was maxed out meaning all my valves and seats are good. Going to replace timing chain, pushrods and find a dowel pin for the cam. Then putting it back together. Still going to find a 351w roller motor.
Old August 11th, 2010, 01:34 PM   #51
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
you have to get any abs eliminator there is no way to run it if your running the turbo setup if you go on boost brothers website i believe they have something on there for it
Old August 11th, 2010, 02:08 PM   #52
n/a
one thing i'd recommend, on top of your leak test, check out your lifters, when mine backed off, i had the little tabs around the roller part of the lifter actually break off
Old August 11th, 2010, 09:51 PM   #53
95 & 97 GT
I didn't think of that, thanks I will take the intake off and pull the lifters to inspect them.
Old August 18th, 2010, 02:05 AM   #54
SeaBiscuit94's Avatar
1994 Mustang GT
SeaBiscuit94 is on a distinguished road
im actually thinking about buying the boost brothers turbo kit and i was wondering whats your opinion so far on the kit?
Old September 11th, 2010, 10:53 PM   #55
95 & 97 GT
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/155094-boosted-5-slower.html
I'm trying to get these! - Page 4 - Superiorstangs This thread Refback March 30th, 2010 08:47 AM
I'm trying to get these! - Page 4 - Superiorstangs This thread Refback March 30th, 2010 03:05 AM
I'm trying to get these! - Page 4 - Superiorstangs This thread Refback March 30th, 2010 03:00 AM
Threads Similar to: Boosted 5.slower
Why are auto's slower?? Hasenbonkers 99-04 150 May 14th, 2010 12:58 PM
slower with 4.10's, again. trueblue02GT 99-04 69 September 14th, 2009 12:03 AM
boosted 07 gt ??? forcefed'0715 2005 - 2010 5 April 5th, 2008 10:07 AM
17 to 18. How much slower? RC02GT 99-04 2 June 10th, 2007 07:28 PM
New wheels slower e.t.'s? Jeff99gt 99-04 4 February 6th, 2007 03:28 AM
