Discussing problem! in the 94-95 Forum. ok i have a problem, i got a 94 5.0 and it used to ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
problem! |
mine had similar issues and I replaced the mass airflow sensor. I got a remanufactured one for 45.00 at auto zone.It runs great now
sounds like MAF to me. I had the same issue but worse and it fixed it.
yeah i took it up to my friend and he said some kind of hose was loose so he hooked it back up, it sounds a lot better but it didn't help the performance much...its like it just lags along in 1st gear...but he said a good tune up should help?
All Throttle with a Bottle
12.91@105.29 @ 5800 FT
I would try the MAF, if its messed up it will definatly make the car run differently!
ok i just changed the plug wires, distributor, and cap, and tomorrow i will try new spark plugs, if it all fails i will try the MAF...thanks for the help maybe i won't have to drive it off a cliff now haha..i'll let you know if it helps
hey i just put new catalyc converters on it...the old ones were clogged with carbon and it runs better than i have ever seen it run but thanks anyways
Threads Similar to: problem!
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
| Has your car ever had a problem? | JASonic | The Clubhouse | 17 | September 19th, 2007 05:19 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 01:36 AM |
| RIM Problem and Help | trueballerisme | 2005+ | 70 | August 21st, 2007 08:55 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 13th, 2006 11:46 PM |
