blew the clutch!!!!
last night i was driving down the road and my clutch gave out. i was wondering what i should buy, should i buy a kit like this one from jegs? includes:
Ford Racing Cast Iron Flywheel Ford Racing ''King Cobra'' Clutch, Pressure Plate, and Throw-Out Bearing Clutch Cable and Quadrant Clutch Fork Pilot Bushing Pressure Plate Bolts and Dowels 4 Quarts of Redline MT-90 555-60100K 5.0L Complete Clutch Kit -$438.99 or should i just a clutch kit like this one from summit Brand: Ford Racing Performance Parts Product Line: Ford Racing Clutch Kits Input Spline Quantity: 10 Input Shaft Diameter (in): 1.062 in. Disc Diameter (in): 10.500 in. Disc Diameter (mm): 267mm Disc Material: Organic Disc Style: Sprung hub Pressure Plate Style: Diaphragm Throwout Bearing Included: Yes Throwout Bearing Style: Standard Alignment Tool Included: No Pilot Bushing Included: No Flywheel Included: No Counterweight Assist: No Mounting Hardware Included: No Quantity: Sold as a kit. Notes: This is the King Cobra kit. Clutch Kit, Organic, 1 1/16 in. Diameter Shaft, 10-Spline, 10.5 in. Diameter Disc, Ford, Mustang, $184.95 im not sure what whould be best, replace everything now with the kit from jegs or go with the one from summit. thank you for your time and input! |
Do you know for a fact the clutch died? The cable could have gone to that junkyard in the sky.
yeah i am 90% possative that it is the clutch. i am going to have it looked at later today. if it is the clutch, which kit should i buy that i posted in the main section of the forum.
Moderator
whatever you do dont get the king cobra you will hate it. i threw mine out last night. peice of shit.
There's a reason Ford codenamed them the Terminator
make sure you get a dual friction clutch, and i could get a lightweight flywheel not a cast iron
If I was you I would get a SPEC Clutch. I put a stage 3 in mine and I have never had any performance clutch that grips like that. The website is: specclutch.com
Threads Similar to: blew the clutch!!!!
| I blew the motor | cams-shelbycobra07 | 5.0 Mustangs | 125 | May 6th, 2008 02:25 PM |
| I think I blew out!!!! | Top Gear | Audio/Video | 21 | September 26th, 2007 03:47 PM |
| Blew up my engine and need a new one.... | 99v6stang | V6 Mustangs | 45 | August 13th, 2007 12:00 PM |
| Blew it and knew it.....! | Sickstick | V6 Mustangs | 23 | May 27th, 2007 02:06 AM |
| Blew Something | JRubin2000 | 99-04 | 11 | November 2nd, 2006 07:01 PM |
