sn 95 build pics coming soon
Old March 16th, 2010, 06:17 PM   #1
89 lx
11.28@117
B John is an unknown quantity at this point
im building a budget sn 95 hoping for 11.70s all motor.
i got a sn95 rolling chasis for 800, guy started but never finished it, nice paint, already has kyb adjustable suspension, 2" drop springs, cam plates, and 4.10 a locker and hawk pads with slotted rotors. just dont have seats
i got a 347 forged short block for a good price, im gonna use e7 ported heads, with 2.10 1.60 valves, and LS valve springs, 1.7 roller rockers, x303 cam, dual plane polished intake, not sure on the carb yet, im thinkin 750dp, and a c4 from tci with a 3kstall goin behind it. all of the parts are spare parts i have except for the new short block and the tci trans.
the engine is getting cam installed and degreed, dist getting locked out, and heads being ported to flow 200cc intake and 180cc ex with the x cam, should be finished tomorrow so ill post some pics of the car and engine, im hoping to have it done by the end of the month because i got to leave for bct pretty soon.
so far all ive done is the wiring for the fuel and ignition system, ran 1/2 fuel line and installed a f250 radiator and a f250 trans cooler.
TT 347 stroker
Old March 17th, 2010, 07:45 PM   #2
89 lx
11.28@117
machine shop just called the motor will be done after 6, but i ran into some probs with the car. had to go to the jy to pull a ignition switch, the previous owner cut it out and i couldnt get power to the dash, headlights etc. without it. so i got that fixed then i found out the brakes and rear turn signals didnt work. got a wiring diagram and noticed the guy took out a piece of body harness that runs power to rear brake lights. so back to the jy to get that harness then to go pick up the motor.
TT 347 stroker
Old March 17th, 2010, 07:58 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
nice man! sounds like a fun build...why would you cut all that out is beyond me.
4V swap in the works
Old March 18th, 2010, 12:03 AM   #4
89 lx
11.28@117
k got alot done on the car today. its a sn95 i ran the vin found outs its a 94 that came factory with a v6. i put some craigers on it that i had sittin around, got some new tires for it to. i looked under the car, it already has some drop springs j&m upper and lower control arms with poly bushings, kyb adjustable rears, and in front, poly bushings, kyb adjustable and camber plates, slotted rotors and hawk pads all the way around. got the interior wiring all setup and got all the lights working even got the radio working. got my ignition box and fuel pump he left in it all wired up to.
TT 347 stroker
Old March 18th, 2010, 12:11 AM   #5
89 lx
11.28@117
i found alot of cool stuff the previous owner left in the car to, he left a billet roller cam, i took to to a machine shop and they measured the lift, 760 intake and 804 exhaust, a rci fuel tank and a edelbrock air fuel ratio monitor.
TT 347 stroker
Old March 18th, 2010, 12:27 AM   #6
89 lx
11.28@117
pickup up the motor today to, this is what im working with
347 shortblock, procomp forged stroker crank, procomp i beams forged, srp flat top forged pistons. dss main girdle. hv oil pump, 7.5qt oil pan with pickup.
im using some e7 heads i had sittin in the shed, put oversized valves 2.10 1.60 valves, LS double valve springs with damper, and had them ported out. the cam im using is an x303 cam with a 542 lift on in and ex. after the port job these e7 heads are flowing 246.6 at .500lift and 248.1 at .550 lift on intake 177.6at .500 and 182.4 at .550. not to bad for some cast e7 heads. with these heads im making 9to1 compression. im using a mls head gasket and arp head bolts. and some harland sharp 1.7 roller rokers i had sittin around from an old build. also i threw in some noisy gears, i like the way they sound. most the of exterior components i had just sittin on a shelf so i put them to use. some shorty headers, oem water pump i painted, aluminum timing cover, i had a hei style dist so i took it to the engine shop and had the guys there lock it out and wire it for the 6al box, i used a new set of comp cams hardened push rods, valves covers i had, and the intake is a polished dual plane intake made by professional products i got off a friend for 50 busk. i started it on stand to set timing, i used a 600cfm carb to do that but i want a 850dp to run with it. hopefully i can have that next week when i put the engine in.
TT 347 stroker
Old March 18th, 2010, 01:11 AM   #7
89 lx
11.28@117
couldnt post the pics on here so i made a quick site to show my progress on the car. i put a few pics up on there here is the link http://sn95build.yolasite.com/
TT 347 stroker
Old March 18th, 2010, 05:48 AM   #8
89 lx
11.28@117
now im debating on what trans to run, i can use a tci c4 but will have to modify the trans bracket since it is shorter than the aode that the sn95 cam with, also will need a bigger driveshaft, i know this cuz i just finished another sn95 like a week ago. or i can get a rebuilt aode with manual shift kit that cam out the sn95 i just worked on, has maybe 500 miles on it, not even broken in yet, and my friend will give me that one for 250 since i did the work on his car for dirt cheap. and with the aode it with bolt right in and i even got the driveshaft already.
TT 347 stroker
Old March 18th, 2010, 02:13 PM   #9
roast&toastEM's Avatar
1994 Mustang GT
roast&toastEM is on a distinguished road
nice build. i like hearing about it. looks like its all comin together pretty well so far too. gl
1994 Mustang 5.0
Old March 18th, 2010, 03:48 PM   #10
89 lx
11.28@117
decided im gonna go with the aode since my friend is gonna give it to me in exchange for some wiring work. he says its a little beffed up and will handle over 400, so since im getting it for free pretty much, i figure what the hell.
TT 347 stroker
Old March 19th, 2010, 03:41 PM   #11
89 lx
11.28@117
picked up the aode today gonna pull the pan and put a new filter in it and check out the work that was done to this vb. ill post up some pics later.
TT 347 stroker
Old March 20th, 2010, 12:25 AM   #12
89 lx
11.28@117
got some more pics up of the trans im gonna use and the valve body kit it has in it. http://sn95build.yolasite.com/
TT 347 stroker
Old March 20th, 2010, 01:20 AM   #13
1994 Mustang GT
nice!
1994 Mustang 5.0
Old March 20th, 2010, 03:23 AM   #14
89 lx
11.28@117
thanks its coming along good, quicker than i thought, i almost got all the little stuff the only thing im missing is a carb and some racing seats. hopefully i can make my deadline by the end of this month if not i gotta finish by mid april.
TT 347 stroker
Old March 22nd, 2010, 12:39 AM   #15
89 lx
11.28@117
today i made a dash insert out of a piece of plywood i had laying around, i needed it cuz the car was missing it and i needed a way to mount my stereo, switches, and air fuel monitor. and i used plywood cuz i didnt want to spend 80 bucks on a custom insert. here is the new pic i posted up. http://sn95build.yolasite.com/home-made-dash-insert.php
TT 347 stroker
Old March 22nd, 2010, 03:37 AM   #16
1994 Mustang GT
haha. nice, well it works right. so y not go with it.
1994 Mustang 5.0
Old March 22nd, 2010, 03:41 AM   #17
89 lx
11.28@117
lol exactly what i was thinkin. tomorrow im gonna get the oil and water temp guage, and mount em to the cluster trim, my stock volt guage works so im gonna leave it as is.
TT 347 stroker
Old March 24th, 2010, 02:38 AM   #18
89 lx
11.28@117
i bought an auto meter tach so i gotta wait to get the gauges next week, and my wife said she will buy my carb and racing seats, so once i get that ill be ready to get the car on the road, i got some 5 point belts the other day to. ill post up some more pics tomorrow.
TT 347 stroker
Old March 27th, 2010, 05:45 AM   #19
89 lx
11.28@117
picked up the carb i wanted, 750dp mech secondaries, and choke has been deleted. http://sn95build.yolasite.com/
TT 347 stroker
Old March 30th, 2010, 10:55 PM   #20
89 lx
11.28@117
just got the engine dropped in, got all the wiring hooked up and started to adjust valves but one of the rockers wasnt on the center of the valve. pulled the pushrod and noticed it was tweaked a bit. enough to throw the rocker off. so now i gotta order a whole new set cuz they dont sell them singles. but for now im gonna throw on a stock one. till i get the extra money to order the comp cams pro magum pushrod set.
TT 347 stroker
Threads Similar to: sn 95 build pics coming soon
new build coming soon bobnasty 99-04 0 August 8th, 2009 05:31 PM
Senior Pics (opening myself to all coming comments lol) RavensChild The Clubhouse 49 March 18th, 2009 12:50 AM
pics of the build sniperrider 5.0 Mustangs 12 March 16th, 2009 12:24 PM
Out with the old...in with the new clutch(pics inside)(videos coming soon) WilltheThrill The Clubhouse 18 February 11th, 2009 01:37 PM
Where r the profile pics coming from? 1998_svt_cobra 96-98 9 November 28th, 2006 10:25 PM
