trick flow top end kit on a dss 331
Old March 11th, 2007, 10:10 PM   #1
stangzilla 331 is on a distinguished road
how much hp should i get 10.7 to 1 copression stage 1 cam how much will a stage 2 cam make
Old March 11th, 2007, 10:12 PM   #2
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
800 at least.
There's a reason Ford codenamed them the Terminator
Old March 11th, 2007, 10:14 PM   #3
what!!!!!!
94 gt built aode 331 dss stroker trick flows and a list for days name it i changed it F AN LS 1,4,6 ALL OF EM
Old March 11th, 2007, 10:14 PM   #4
Moderator
89StangGT's Avatar
SVT Cobra Mustang
it was a joke, id really have to know more of your set up.
Old March 11th, 2007, 10:17 PM   #5
30lb injectors 90 mm mass cold air underdrive pullys msd dist crane ignition adj fuel pres wedge heads 10.7 to 1 comp 331 stroker all forged and so on i was told from 370 to 400 with a good tune
Old March 11th, 2007, 10:26 PM   #6
Moderator
89StangGT's Avatar
SVT Cobra Mustang
id say you could see 400 with a good tune no problem.
Old March 11th, 2007, 10:28 PM   #7
when i get all in will it run ok to drive to a dyno
Old March 11th, 2007, 10:29 PM   #8
Moderator
89StangGT's Avatar
SVT Cobra Mustang
should be fine as long as you dont get on it too hard. baby it.
Old March 11th, 2007, 10:36 PM   #9
thanks ill have pics soon and alot of how do i do that stuff
Old March 21st, 2007, 10:53 PM   #10
btatar50 is on a distinguished road
hey i have a 94 gt and i was wondering if i put the same trick flow top end kit in my stock 302 with long tube headers, off road xpipe, cold air, underdrive pullys, magnaflow cat back, 30lb injectors, mass air. and then upgraded the cam to stage two what kind of horse power to you think i can see to my rear wheels. (FYI with everything but that top end kit i have 240 to the rear wheels)
Old March 30th, 2007, 07:45 AM   #11
first of all you dont need a x pipe you will lose low end torqe x pipe is for top end 600 and up hp cars i lost power with a x pipe and i dont know why you want long tubes go with shorties and a h pipe youll get better low end torque you might see 350 hp with a stock bottom trick flow made 350 on a 306 flat top so you might see thator at least close to it your gona need a major tune job also 94 95 are a bitch when you go crazy on them
Threads Similar to: trick flow top end kit on a dss 331
Top End Kit AFM or Trick Flow rvdooley 5.0 Mustangs 5 November 12th, 2007 06:22 PM
Trick Flow Top end kit. Timm10221 5.0 Mustangs 23 October 17th, 2007 02:36 PM
trick flow Iownastang 5.0 Mustangs 7 July 6th, 2007 12:50 AM
gt 40 or trick flow? 95wip 94-95 8 April 21st, 2007 10:42 PM
Trick Flow 92mustanglx 5.0 Mustangs 0 September 3rd, 2006 05:13 PM
