Water tempature sensor?
Do you know where it is? I have a 95 5.0. I notice that my Temp gauge either doesn't work or is just chillin by the "N" of normal. Then sometimes its by the "O" where I think it should be. I am thinking loose connection or bad sensor. Please someone point it out to me! (Pictures are best)
Last of the 302's
Road Racing Rookie
Facing the front of the car, it's on the right side of the lower intake on the front. It's rite behind the coil.
![]() Victor ( goofyfeet) Oliver P.B.M.C. Member Track Addict |
The temp. gauge sending unit is right at the front of the lower intake on the driver's side behind the coil and distributor. It has a single wire going to it so you can't miss it or mistake it for anything else.
If the gauge nearly always reads cold or is at the cold end of normal, that indicates a high resistance in the circuit. The reason could be either a bad sending unit or a poor connection. Let us know what you find.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Ok thank you guys so much! I will check it soon. I will for sure let you guys know whats up!
Ok so is this it?
![]() Also I have a question about my radiator hoses. I have some hoses left over from my 89 5.0L. Can I use them for my 95? They are brand new never been used. |
95 mustang gt
no its on the driver side front of the lower intake behind the coil
Last of the 302's
Road Racing Rookie
No, it's in this area
I see... I think I found it...
Ok so I did find it. It has a single red wire running to an elbow that plugs into a thing thats screwed into the top of the engine. (Sorry I lack technical terms...). I pushed on it and it went down so I guess it was loose.
Question: What is a "Normal" operating temp via temp gauge? Like around the O or M or what? I just threw a new water pump and thermostat in it. =) Donuts here we come! |
95 mustang gt
it depends on the temp out side but no more than half way on the gauge with ac on
mine runs at half on a hot day with ac going |
hmmmm well I dont use my AC cause well I have never had one! So I just roll down the windows and lose weight! My seems to operate on the colder end of the gauge around the N and O all the time hot or cold outside.
95 mustang gt
thats perfect thats what mine does with a totally new cooling system
Cool cool. I still may change the sender unit because I can. =p I guess knowing how hot your car is running is a good thing yes?
Threads Similar to: Water tempature sensor?
| coolant tempature | redrocket | 99-04 | 6 | April 29th, 2010 01:56 AM |
| Just drilled and tapped my 2nd water temp sensor on my pi manifold check out pics | JeffroEinstein | 96-98 | 20 | April 23rd, 2010 11:59 AM |
| aftermarket water temp sensor/gauge | ajm | 99-04 | 0 | April 21st, 2009 04:37 PM |
| Slight water leak out of the water neck | Novanutcase | 99-04 | 4 | December 23rd, 2008 08:37 PM |
| Water temp sensor relocate? | ckjacobus | 96-98 | 2 | August 12th, 2007 09:56 AM |
