Intermittent start problem
Old May 5th, 2010, 02:53 PM   #1
1995 GT
4Ever
Red95_5Oh is on a distinguished road
Send a message via AIM to Red95_5Oh
Hiya,
I am having a problem starting my car sometimes. The engine just turns over and doesn't start. I can hear the fuel pump prime and I believe its an electric fuel pump cause I can hear it when it runs.
I am not sure when the last time the car was tuned up. I haven't taken out the plugs yet or anything but the oil looks clean.
Few questions.
What type of plugs and wires should I use?
What type of oil should I use? My uncle said to use the Castrol GTX High mileage oil.
Where should I start trouble shooting?
My cousin has a 98 V6 and is having the same problem. His dad said to change the fuel filter and spark plugs.
I am thinking that it may be the igniter. (You know the coil thing that delivers spark to the dizzy.)
Any suggestions?
I am not looking to turn my car into a speed demon. I just want to keep it running good. Every other car I've owned i've dumped alot of money into with after market parts and stuff but I just want to keep this car stock and running GREAT. So please let me know what's up.
Old May 5th, 2010, 03:52 PM   #2
bustedknuckles's Avatar
95 GT, 06 vert v6
havent ran
bustedknuckles is on a distinguished road
well i had the exact same thing and i found that my exhaust had melted my starter wire that connects from the motor of the starter to the soleniod....
ive also had my coil go out... spray starter fluid in the intake and see if it fires up then, if so its prolly your coil...
if not starter
more than likely
1995 GT - Light Mods (getting more fun!!)
2006 Vert V6 - This is for the wife! she loves it!
Northeast Ohio
Old May 5th, 2010, 04:47 PM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
A bit more info is needed to help you make the correct diagnosis.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old May 6th, 2010, 09:43 PM   #4
1995 GT
4Ever
Such as?
Well... it doesn't matter if its cold or not. I don't think its the starter because the engine is turning over but not starting (Like actually running). It just turns over and over and over etc... If you try a few times then start it fires right up. Also I noticed sometimes when the car starts it like BARLEY starts. I.E. fires up at only like 2 or 3 hundred rpms then catches. I think its either the coil or fuel filter.
Old May 7th, 2010, 03:25 PM   #5
95 GT, 06 vert v6
havent ran
Does It Run Fine If You Spray Starter Fluid In The Intake Then Stall When It Runs Out
Northeast Ohio
Old May 7th, 2010, 03:27 PM   #6
95 GT, 06 vert v6
havent ran
Sounds Like A Coil If So
Northeast Ohio
Old May 8th, 2010, 11:52 AM   #7
1995 GT
4Ever
I have yet to try the starter fluid idea... I shall buy some.
Old May 9th, 2010, 08:59 PM   #8
azkevlong is on a distinguished road
Sounds like you need a new fuel pump. Mine was doing the exact same thing until I finally broke down and replaced the pump. It's bleeding off pressure while it sits. Cycle the key to trigger the FP relay 3-4 times before you start it, if that helps it's the FP.
Old May 11th, 2010, 07:00 PM   #9
1995 GT
4Ever
ok... it hasn't done it since I posted up this thread. But my water pump just went out =(
Threads Similar to: Intermittent start problem
Problem during a cold start-up wolfmania 99-04 10 April 13th, 2010 02:15 AM
Kinda slight no start problem.. FearLS82GT 5.0 Mustangs 5 January 3rd, 2009 08:53 AM
Weird intermittent problem? jivepepper 99-04 9 September 3rd, 2008 05:32 PM
85 GT Start Problem beheivjer 5.0 Mustangs 6 April 1st, 2008 09:11 AM
problem with cold start 6banger96 V6 Mustangs 5 November 7th, 2007 03:49 PM
