Gauge play
Old May 10th, 2010, 10:44 PM   #1
Foxmoto28's Avatar
'94 GT Coupe
Foxmoto28 is on a distinguished road
Gauge play
So recently I've been thinking the stang has been overheating but haven't been smelling any anti-freeze or anything. Now I'm thinking it's electrical. The other night I was driving to a restaurant and noticed it playing games. It would go from cold to hot (like normal) and then it would go down to halfway and then back to hot and then cold, back and forth.
Am I looking into something horrible?
How can I fix this and what are things to look for to make sure that my car isn't actually overheating?
1994 5.0 Coupe GT
Old May 10th, 2010, 11:01 PM   #2
1994 Mustang GT vert
redturbo5.0 is on a distinguished road
first i would check to see if your thermostat is working properly. then check your radiator cap or just replace it if not sure
Old May 11th, 2010, 09:31 AM   #3
mutlyi4's Avatar
95 mustang gt
mutlyi4 is on a distinguished road
get an infrared thermometer (can get one at sears for like $30) and check the engine temp at the thermostat and the coolant temp sensor and compar to your gauge if it matches you have a problem if not its just the gauge being off maybe the cts or the gauge
Old May 11th, 2010, 12:39 PM   #4
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Sounds to me like the gauge sending unit is on the fritz.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old May 11th, 2010, 07:01 PM   #5
1995 GT
4Ever
Red95_5Oh is on a distinguished road
Send a message via AIM to Red95_5Oh
yeah mine is doing the same thing...
Old May 14th, 2010, 11:25 PM   #6
Foxmoto28's Avatar
'94 GT Coupe
My dad told me to take a flame to the thermostat to see if it opened up; guess they used to do that it they don't anymore. Would the one on my car do this? Or is that just old and outdated?
Old May 15th, 2010, 09:43 AM   #7
mutlyi4's Avatar
95 mustang gt
should work but i use boiling water so as not to take a chance on damaging the thermostat
Old May 16th, 2010, 11:39 AM   #8
1995 GT
4Ever
Quick question. Where should my thermostat needle be? I do believe my sender unit is messed up. It moves from just above cold to around O. I just changed my water pump hoses and thermostat.
Old May 19th, 2010, 04:34 AM   #9
mustangbrad94gt is on a distinguished road
our temp gauges are known for problems, accuracy is + or- 20 degree's at best, I switched to a autometer electric 4337 at 50 bucks, spot on accurate
Old May 19th, 2010, 05:47 AM   #10
Mustang68 is on a distinguished road
agreed.. that or his wiring shorting out somewhere...
Old May 21st, 2010, 10:59 PM   #11
Foxmoto28's Avatar
'94 GT Coupe
It was that sending unit, thanks guys.
Threads Similar to: Gauge play
Play by Play on Speedo re-cal MacGill 99-04 10 May 3rd, 2010 06:00 PM
New item - Auto Meter ecometer fuel mileage gauge - plug and play @ PFYC.com PFYC PartsForYourCar.com 0 July 1st, 2009 09:55 AM
