LinkBack (1) | Thread Tools |
#1
GT40P heads 1.7 RR's Valve cover clearance Issues
Just installing my GT40P heads on my 1995 5.0 and put on 1.7 Roller rockers. Now having issues with valve cover clearance...!! Removed baffles and still a no go.. I have a 97 explorer intake to go on the engine as well during this install. Any recommendations on what valve covers to run to get rocker clearance and still clear the upper intake ?? Anyone have this problem before ?? I thought that with removing the baffles I would have clearance.. Guess what I read was incorrect ???
Thanx, Tom Last edited by lakefrontlivin; May 20th, 2010 at 10:32 AM. |
trickflow standard height will do the job, and will clear the back of alternator, this is what i run, about 110.00 shipped at summit racing
#3 | |
Tom |
1995 GT 5.0
![]() iTrader: 1 reviews
What valve covers are u trying to run?? if its the stock 94-95 covers then they will never fit..... the Fox valvecovers work with the baffles removed, i have a set of 84' power by ford valvecovers and the 3/8" metal gasket with no clearance issues...
1995 Mustang GT ,Out with the 302 in with a Viper V10 (Still a work in progress)
Looks like I'm going to go with Summit Tall Aluminum covers and will be putting on a 1" spacer from Trickflow. Also putting on a Hood Scoop.. Guess there will be room now !!! lol
Thanx All. Tom H . |
you might run into alternator clearance issues with the tall, I had to modify some frpp talls to clear alternator, im running trick-flow shorts, comp rollers, 585 lift, no clearance problems, will also clear alternator on our sn95's
#8 | |
![]() Tom H, |
Got the 1" spacer.. Now will have to go with a hood scoop... Realized that now having a problem with clearance on tb elbow adaptor... WTF.. It just keeps on going and going and going... Tom
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/166240-gt40p-heads-1-7-rrs-valve-cover-clearance-issues.html
| Thread GT40P heads 1.7 RR's Valve cover clearance Issues | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 4th, 2012 10:49 AM | |
Threads Similar to: GT40P heads 1.7 RR's Valve cover clearance Issues
| GT40P heads 1.7 RR's Valve cover clearance Issues | lakefrontlivin | 5.0 Mustangs | 7 | May 17th, 2010 07:34 PM |
| valve cover paint issues | S281 | General Car Care & Detailing | 6 | June 23rd, 2009 09:59 PM |
| Solid mounts and clearance issues | recklss83 | 94-95 | 5 | December 9th, 2008 02:23 PM |
| Clearance issues | Pharoh | V6 Mustangs | 9 | April 22nd, 2007 02:21 PM |
