02 Mustang GT
stiff clutch/fork play
arrite posting this for my buddy with a 94. hes had his tranny gone through by a local trans shop and they freshened it up (though i really dont trust them that well), a new stock replacement clutch kit was put in, and just today we did an adjustable cable, firewall adjust, and aluminum quadrant. it grabs good, but his clutch pedal has almost no travel at all (about half of my 96's) and is about as stiff as pushing a rock through caramel. now while we were doing the cable i noticed his had a lot of play in his clutch fork - about an inch or so. is that normal ? i know t5's and 5.0's in general are stiffer than t45's and 4.6's, but damn that clutch pedal is hard - even compared to my buddy's 4 eyed fox. any advice is appreciated.
Priest of the Car Gods
Which aluminum quadrant did you use? Pedal effort is going to be determined by a combination of the quadrant's ramp, the tension of the return spring, and the clutch itself. If it's a stock replacement clutch, it should change the pedal effort, and I doubt the shop replaced the return spring with something super-heavy, which leads me to think it's the ramp of the new quadrant.
02 Mustang GT
its a upr triple hook on the middle hook setting.
Have you tried it on the other hooks? I'd be willing to bet the third hook (farthest from the firewall) would be most likely to provide a stock feel.
02 Mustang GT
Rev I couldn't get the cable on the fork with the cable on the farthest hook from the firewall. Even with a prybar. Couldn't the play in the clutch fork, or more specifically the throwout bearing retainer cause the stiff pedal and lack of pedal travel?
I dunno man... My 89 5.0L clutch was stiff as a board. I mean I had to put all my weight into it sometimes to get it to the floor. I changed the fork, cable and quadrant with no change. I heard maybe its the spring that pulls the pedal back up that might need to be changed?
02 Mustang GT
in any case - man am i glad i got a 4.6/t45 with a butter pedal
lol. guess ill just tell him to figure it out.
Were you trying this with the firewall adjuster screwed all the way in?
02 Mustang GT
that mightve been the issue. i kinda gave up on his car. wouldnt start two days after we finished that install. and a new battery and starter later - its still not starting..
Threads Similar to: stiff clutch/fork play
| Clutch fork | sctravis77 | 4V / SVT | 1 | January 7th, 2010 09:31 AM |
| clutch stiff every now and then.. | soop7 | V6 Mustangs | 13 | October 15th, 2008 12:23 AM |
| Clutch Fork | Euroeater95 | 94-95 | 0 | September 25th, 2007 02:58 PM |
| Clutch fork. | Stangzilla | 5.0 Mustangs | 1 | July 9th, 2007 10:37 PM |
| stiff clutch | purplepony96 | 5.0 Mustangs | 1 | November 21st, 2006 05:00 PM |
