1995 gt
?? high 12?
help with 95 gt newbie ques
what is the stock tb size on a 1995 gt 302? also if someone can tell me the best way to lower car about 2 in? what are the best plugs 2 use? i have bbk h pipes no cats but it looks like stock ford mufflers what should i replace these with for best hp? 150000 miles mobile 1 oil 20 50? thanks guys
55mm; i would use eibach springs for lowering.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
#3 | |
60mm
With a complete suspension lowering kit. Keep in mind that you'll need a bumpsteer kit and adjustable caster/camber plates with that degree of lowering. Stock Motorcraft If the crankcase was already being filled with synthetic, continue it. Otherwise use a good quality 10W-30 dino oil. You don't need anything thicker than 30 weight unless you either live in a hot climate or the oil pressure is marginal due to worn engine bearings. In cold winters you could go down to 5W or even 0W oil viscosities.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
#4 | |
Stock 94-95 Mustang GT came with a 55mm throttle body, not 60mm.
[QUOTE=Bullitt95;2892845]I measured the stock TB that I had on my '95 and it's definitely 60mm! Do you think I had a factory freak?[/QUOTE
Not sure, but the book claims a 55mm...i read somewhere its actually closer to 58mm but they classify it as a 55....i never did measure my stock one though..its in a box in the garage, maybe ill measure it for shits and giggles and see what we get.
1995 gt
?? high 12?
1996 Mustang 5.0
14.0
Yea on the line,the 5.0 is slowwwwww.Get the 3.73's and a 70MM TB with the intake i was telling you about..
![]() A Ricer is a stupid young idiot who thinks he is a car expert after watching The Fast and the Furious, Pimp My Ride, and playing Need For Speed Underground-LMFAO |
#9 | |
As far as getting killed off the line, what is the issue? Is it a hooking up problem or not enough low end torque? If your spinning tires off the line, changing your gear ratio will only make it worse....get some good tires first, then change the rear gear.
#10 | |
94 GT Vert, 95 GTS + 95R
I have Steeda sports on my 94 vert with a 2" drop. My 95 GTS has Eibach Pro with a 1.5" drop. And the Cobra R has the stock FMS springs. As far as plugs, Motorcraft is good, but I use NGK V-Power plugs. I have been extremely satisfied with their performance in all my Stangs. I have the MAC Pro-Chamber H-Pipe on the 94 vert and 95 GTS. The vert has a complete MAC Flowpath exhaust while I have FlowMaster 40's on the GTS. The MAC has a very nice low tone and very little drone... The flows sound like Flows with the normal drone... If the car has had conventional oil in it... Stick with it... I use synthetic, but my Stangs have low miles and have had synthetic since new... IMHO Gears are the best bang for the buck... And you can feel the difference with the Butt Dyno!!! If the car has the stock air box, you can remove the silencer and gain aprox 2-5hp. Free Mod... Defiantly do your research and don't waste your money on "Snake Oil Mods"
![]() Tuned by Ramseys Performance Tampa. Last edited by The Whistler; June 4th, 2010 at 11:28 PM. |
#11 | |
1995 gt
?? high 12?
![]() bck0977
Threads Similar to: help with 95 gt newbie ques
| S/C oil ques.??? | Rich11 | Modular Mustangs | 11 | January 28th, 2010 02:45 PM |
| swap ques | Mustang RacR94 | 4V / SVT | 5 | July 12th, 2009 01:05 AM |
| ques for ya fella;s | Mustang RacR94 | 4V / SVT | 3 | July 9th, 2009 08:52 PM |
| quick ques | Mustang RacR94 | 4V / SVT | 6 | September 16th, 2008 01:15 AM |
| ques. about o2's | armymike63b | 4V / SVT | 14 | July 29th, 2008 02:39 PM |
