95 engine gasket replacement help I've got a 95mustangGT 8 cylinder 5.0 engine . the left engine gasket needs replacement . I cant afford taking it to the mechanics ( they charge a lot down here ) i want to do it my self ( I have never worked on a car before ) want to know if i can get any help form you guys . or is there a video on a step to step tutorial to do it . ( how i know the gasket is blown is because water in the radiator finishes in matter of minutes and the engine oil is all mixed up with water . i checked the engine oil its all brown and thick now . plus when you put your hand on the left side cylenser you can feel it shooting water out there for the left side gasket is blown from my knowledge of cars ) again step to step on what needs to be done ... and another thing my car heats a lot from underneath and when i turn off the car makes a lot of ticking sounds from the head . though the hear gages are not showing over heating . even if the cars running i open the door and can feel the heat coming from underneath what is that about ??? |
95 mustang gt
as a mechanic my self if you have no knowledge of working on cars i would not personally try this but if your determined get a Haynes manual and prepare to buy some tools
Will look in to Haynes manual . Thanks .
and i am determined but again i will have friends working on it with me . thanks again !! though i would have loved some more info on it . |
95 mustang gt
its hard to describe what has to be done as the engine has to be striped to the block everything must come off you will have to discharge the ac and pull the radiator then pull the p/s pulley to access the bracket bolts both accessory brackets must be remove the intake has to come off and of course the exhaust manifolds will need to be removed just make sure you torque the heads in the right order and to the right specs oh and make sure to clean ll gasket surfaces very good to avoid leaks
and the heat from underneath the car check your cats they may be clogged up partially |
1996 Mustang 5.0
14.0
It is VERY defficult.I mean,you have to TQ the heads perfect and they have to be TQ down,then back them out then a final TQ.The only thing you need to get rite is the heads and the rockers.After that,everything else is a breeze...
![]() A Ricer is a stupid young idiot who thinks he is a car expert after watching The Fast and the Furious, Pimp My Ride, and playing Need For Speed Underground-LMFAO |
i truely believe that if you are mechanically inclined at all and can read you can do this. my sister rebuilt her engine in her jeep with basic tools, a tq wrench, and both books. anything she didn't understand she asked the guys at o'reilly's. personally i'd skip the autoparts guys and just ask us.
you can borrow any tools like torque wrenches from most auto parts places. just buy a decent basic set of tools |
1996 Mustang 5.0
14.0
One of those sears tool things that brings a cash should have everything you need.Youll need a fuel disconnect tool also and youll need to buy some stuff..
Threads Similar to: 95 engine gasket replacement help
| head gasket replacement | tattoo junkiee | 96-98 | 4 | April 22nd, 2010 06:32 AM |
| engine gasket problem | hopper | 5.0 Mustangs | 8 | March 17th, 2009 03:57 PM |
| I need a Engine Gasket kit!! | 03_StangGuy | 99-04 | 1 | March 3rd, 2009 04:17 PM |
| Potential gasket replacement | bwoody1713 | 99-04 | 2 | October 3rd, 2008 12:35 AM |
| Engine Build Up or Engine Replacement... | OcOnnor220 | 99-04 | 8 | July 27th, 2008 03:54 PM |
