upper/lower control arm question
Old June 7th, 2010, 05:31 PM   #1
roast&toastEM's Avatar
1994 Mustang GT
roast&toastEM is on a distinguished road
i am replacing both my upper and lower control arms. i have the uppers done and am going to do the lowers tomorrow. i am using j&m control arms i got off americanmuscle. my question is, after i have both of these on, i am fine to take off the quad shocks right? i want to run 315 tires on 10.5x17 wheels and the quads rubbed. also is the stock sway bar fine or does anyone think i should upgrade it? will it make much of a difference if i dont. anyone who has done this how did it work out? thanks to all who reply
1994 Mustang 5.0
Old June 8th, 2010, 12:22 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Yes you can off the quads. Are you replacing the bushings in the axle housing as well if not you should. The stock sway bar is garbage I have snapped more of them than I have fingers to count on lol.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old June 8th, 2010, 12:28 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I pulled my quads after installing MM LCAs. Ride quality improved significantly, however in freeing up some of the bind, there was more rear roll and it felt like it slightly increased the side-to-side slop that the stock 4-link is known for. (Remedied later with stiffer springs and a panhard bar).
O o
/¯/______________________
\_\
Old June 8th, 2010, 12:39 PM   #4
1994 Mustang GT
any recomendations on which works best?
1994 Mustang 5.0
Old June 9th, 2010, 10:49 AM   #5
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
I have MM lowers, Edelbrock uppers (both sets have spherical bearings at one end to reduce suspension bind) and my quad shocks are in the spare parts bin.
243.5rwhp/284.2rwtq
Mod list in My Garage
Threads Similar to: upper/lower control arm question
Anyone got BBK Upper and Lower Control Arm. stang94 94-95 3 April 24th, 2007 11:17 PM
Upper & Lower Control Arm stang94 5.0 Mustangs 5 March 14th, 2007 06:21 PM
Upper & Lower control Arm install stang94 5.0 Mustangs 3 January 11th, 2007 08:53 PM
Upper and Lower control ARM? stang94 5.0 Mustangs 9 December 6th, 2006 10:39 AM
