Leaking Fuel!
Old June 14th, 2010, 08:04 PM   #1
1994 Mustang GT Convert
N/A
KalSaint is on a distinguished road
Leaking Fuel!
So, the mustang sprung a leak today. Right where the fuel filler neck gets inserted into the gas tank, fuel is leaking. Does anyone know what I need to do to fix this, i.e. what seals the filler neck to the tank so it doesn't leak?
*Insert clever witticism here*
Old June 14th, 2010, 11:22 PM   #2
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
Thats a common problem. Here's what you need from 5.0 Resto.
1979-97 Mustang Fuel Filler Neck Grommet by 50resto at LRS - Same Day Shipping!
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old June 15th, 2010, 09:15 AM   #3
N/A
Thanks. Hopefully it won't be too much of a PITA to change it out.
Old June 15th, 2010, 09:38 AM   #4
N/A
Was just thinking, aside from R&R the grommet, is there anything else that needs to be done with this? Sealant, clamps, etc.? I know there's that metal O-clamp doo-hickey (technical term, it's in Haynes, I swear,) that needs to be removed, but I just want to make sure that I don't overlook anything.
Old June 15th, 2010, 10:20 AM   #5
N/A
Answered my own question. Hooray Google. If anyone else needs to do this:
How To Replace Fuel Filler Tube Gasket *pics* - Mustang Forums at StangNet
Old June 15th, 2010, 07:59 PM   #6
WO3 Anderson's Avatar
1994 Vert 5.0
WO3 Anderson is on a distinguished road
I just replaced this on my brothers 94 did everthing but take the rear tire off. Me and him had very little problem I did how ever lossen the tank straps while he puled the pipe and put it back in we just pulled up on a set of ramps had in done in less than an hour. So while I had my vert up on the lift with the engine out I went ahead and did mine as well. PMCS is always a good thing lol
Old June 15th, 2010, 08:57 PM   #7
N/A
So, I found out why my fuel tank was leaking. It seems that the previous owner (read: idiot) decided not to replace the grommet at all and instead, just sealed it with some plumber-esque type compound. Well, the new grommet is in and appears to be sealing the tank. Really wasn't too bad of a job, especially with my 1 year old helper. Oh wait, he was the cause of most of my frustration.
Threads Similar to: Leaking Fuel!
Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket gills99stang 99-04 66 May 19th, 2012 02:49 AM
cobra fuel hat leaking hardhitter 99-04 8 March 16th, 2010 08:16 PM
Leaking fuel?!?!?!?! flamed 98 gt 99-04 9 November 10th, 2009 02:31 AM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
