'95 GT
Was probably faster before I got it.
Just a few Questions.
What rim size was put on 95' GT's mine has low profile tires and I would like to get Bullit rims with non lo profiles but with out having to recalibrate the spedometer in the process. Any advice please and thank you.
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it? ![]()
i do believe they were 16's from the factory.. the cobras came w/ 17's
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
'95 GT
Thanks. What size of bullit rim (with non lo profile tires) would I need to have the overall same height of wheels, tire and rim together (remember mine are lo profiles) and not have to recalibrate the spedometer?
48.47@ 12.58
what size are your tires now?
95 opalfrost gt
stock gts came w/ 16s as an option you could have them equiped w/ 17s.
You can go w/ 17x9s 275 in the rear and 255 up front, or run 18x10 w/ 295s in rear and 18x9 w/ 265s upfront.
48.47@ 12.58
i knew the rim size.. i wanted to know the tire size since he said it was on low profiles.
i know they tires from the factory arent low pro's. and this guy doesn't want his speedo thrown off and wants a mid profile tire. so basically you go from a 16 to a 17.. thats an inch more of rim. now you need to figure out the difference between the the low pro vs. med pro. tires ie: 225/35/16 +1 inch 245/45/17 so it's a 10mm difference in tire height but an inch different in rim size.. so you minus that inch of rim from 10mm and you have the difference basically. i would have to say that if you went with a 245/45/17 you should be fine.
'95 GT
Ok thanks. What size can I get bullits in.
![]() iTrader: 1 reviews
Dude, just get 17's x 9's, with 245/45/17's upfront and 275/40/17's on rear. I got a 94 GT, thats what I"m running, with NO problems. NONE, NADA, NOTHING, i think you get the point.
Giving Away For FREE PM ME. FREE 351 Block, 90,xxx miles (Non roller block) FREE 94-98 GT Hood (red) |
95 opalfrost gt
The 245/45/17 will work but look outa place better yet 255/40s and 275/45 in the rear.
For 18s 295/35/18 in the rear and 265/35/18 up front. These combos will keep you close to stock ride hight and barely affect your speedo. Im running 18x10 rear 18x9 frnt with the above mentioned tire combo. No problems.
'95 GT
Ok, but on a stock GT like mine are the tire sizes the same on the front and back or are they different like your guyses tires or wait did you mean different rims. But like I said earlier dont want lo pros, mid pros are what I want.
95 opalfrost gt
The bigger the wheel the lower profile you will need to run to keep stock height.
'95 GT
Lets say I went with 15'' rims all around what size tire should I go with. I will go with the same size all around for both rim and tire Wait unless that will thro off the spedom.
And thank you guys for sticking it out and explaining this shit to me I know Im being difficult (not on purpose) but each time I understand a little better.
95 opalfrost gt
Check out the link It should help you with all your tire ?s
http://www.tirerack.com/tires/tirete...¤tpage=7
'95 GT
Yeah if I do change I'll go with 16's and medium profiles all the same size all the way around and just have a professional mechanic at a local ford dealership recalibrate it accordingly. Thanks for the help guys.
i have 17x9's all the way around my car with michelin 245/45's & they didn't throw the speedo at all.. you'll be good if you do that..
'95 GT
Mine are 45/245 or 245/45 and there Toyo brand.
Threads Similar to: Just a few Questions.
| Few Questions | Bies08 | V6 Mustangs | 12 | August 21st, 2007 10:33 PM |
| rim questions | SilverGT04 | 99-04 | 26 | August 17th, 2007 01:54 AM |
| *a few questions* | mustang1072 | V6 Mustangs | 10 | June 28th, 2007 11:59 PM |
| Questions about new car! | Blown93Cobra | 5.0 Mustangs | 6 | June 4th, 2007 03:45 PM |
| 2 Questions | mikethetigerrr | V6 Mustangs | 21 | October 25th, 2006 09:23 AM |
