Passenger Power Window
LinkBack (1) Thread Tools
Old June 16th, 2010, 02:21 PM   1 links from elsewhere to this Post. Click to view. #1
1994 Mustang GT Convert
N/A
KalSaint is on a distinguished road
This has been an ongoing problem for me. My Passenger side power window no longer likes to go up. It will go down if I use the passenger side switch, but not the driver's side switch. It will not go up at all, driver's or passenger's. Every other window goes up and down fine, except the passenger's. I'm 95% positive that power is getting to that side of the car, I'm just not sure if it's the correct polarity. I've jiggled all the wires except for the stretch that goes under the dash from side to side. (I think it's routed under the dash anyways.) Now, I don't think it's a bad motor, because when I take a spare battery and a bit of wire, I can make the window go up and down just fine. I have the wiring diagram from Haynes, but I don't know where the wires are physically ran in the car. Any help would be appreciated.
*Insert clever witticism here*
Old June 18th, 2010, 10:12 AM   #2
anfojo is on a distinguished road
It is most likely the driver's window control switch. Fords in general have problems
with this switch and I've replaced dozens of them. These switches are not the typical
DPDT, there's electronics involved. I may have one.
anfojo@yahoo.com
Old June 18th, 2010, 12:14 PM   #3
roast&toastEM's Avatar
1994 Mustang GT
roast&toastEM is on a distinguished road
pop off the door panel and get test wires and test each control switch on the drivers side and passenger side if u need. i had to do it on my driver side because the switch went out and it affected both sides
1994 Mustang 5.0
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/170416-passenger-power-window.html
window goes up not down | BoardReader This thread Refback September 7th, 2010 09:06 PM
Threads Similar to: Passenger Power Window
Passenger window problem, help! XoXoXMiSSPRiSS V6 Mustangs 10 May 17th, 2010 11:39 PM
Parts for passenger window RayvenHawk General Tech 0 October 8th, 2009 05:05 PM
passenger window N29468 V6 Mustangs 2 June 8th, 2009 11:03 PM
passenger window Squeak PowerShiftz02GT 99-04 4 May 7th, 2008 11:39 PM
Passenger window does not want to go down dgt_mustang V6 Mustangs 7 October 13th, 2007 03:03 PM
