HELP!!!! car randomly won't start, then starts just fine....???
Old June 20th, 2010, 11:51 PM   #1
jjreece's Avatar
1994 mustang cobra
jjreece is on a distinguished road
Hey guys, just got in my car to leave work last night, and I had a hard time starting it, but eventually it started and ran fine, I went home, let it sit half an hour, and it cranked just fine.
today I got up and went to leave for work, and had the same problem, i popped the hood, noticed the wire from my dizzy to the ignition was loose on the cap, so I popped that on tight, and it fired up after a few tries.
After work, same issue, but now it won't start at all, and I don't want to kill the battery, so I left it, I know the PIP sensor in the dizzy is probably at fault, but is there anything else I can check before I pay for that replacement?? money is tight right now.........thanks in advance guys.
Old June 21st, 2010, 04:15 PM   #2
bustedknuckles's Avatar
95 GT, 06 vert v6
havent ran
bustedknuckles is on a distinguished road
coil is only 15 bucks... that went bad on mine and it would start right up with starter fluid but not on its own it would just crank away but never fire
1995 GT - Light Mods (getting more fun!!)
2006 Vert V6 - This is for the wife! she loves it!
Northeast Ohio
Old June 22nd, 2010, 01:43 PM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
A bad PIP sensor or a bad TFI module usually cause random stalling as well as hard starting. If the symptom is only the latter, a bad coil is more likely.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old June 22nd, 2010, 02:06 PM   #4
jjreece's Avatar
1994 mustang cobra
it was actually the fuel pump going out, so just got it out of the shop, seems to be better now.
Old June 23rd, 2010, 12:42 PM   #5
Bullitt95's Avatar
13.546 @ 105.32
Good. Hope the new fuel pump has cured the problem.
Old June 23rd, 2010, 04:58 PM   #6
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
How long has it been since you gave the car a tune up consisting of new plugs, wires, and a coil?
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old June 23rd, 2010, 05:19 PM   #7
jjreece's Avatar
1994 mustang cobra
the guy I bought it from said that was done recently...
Old June 24th, 2010, 09:56 AM   #8
95 GT, 06 vert v6
havent ran
so like 2 years ago... id do it and replace your fuel filter!!
Northeast Ohio
Old June 24th, 2010, 02:32 PM   #9
jjreece's Avatar
1994 mustang cobra
lol probably, I just did the fuel filter like 2 weeks ago, so now the fuel system is good, i prob could do the coil, I was looking at it yesterday, it's a msd ignition, but its a little loose in the housing, and it looks pretty old, the car is starting fine now, but I guess I could replace it for peace of mind.
Old June 26th, 2010, 02:27 PM   #10
Look Ma! My First Post!
mfhill is on a distinguished road
My 94 mustang won't start. But after sitting starts right up
I have a 1994 Mustang and after it has been running will not start. It is like the battery is dead. You can't unlock the doors, roll the windows down nothing works. After sitting for a bit it starts up. This time I had to have it jumped and it took about 10 minutes of charging to get it to start. The battery is brand new. What could it be?
Old June 26th, 2010, 03:19 PM   #11
KV007's Avatar
2003 Mustang Gt
Slow
KV007 will become famous soon enough
alternator?
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi
Old June 26th, 2010, 03:21 PM   #12
jjreece's Avatar
1994 mustang cobra
Originally Posted by KV007 View Post
alternator?
+1
Old June 28th, 2010, 03:51 PM   #13
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
its most likely a bad ground or bad connection
Threads Similar to: HELP!!!! car randomly won't start, then starts just fine....???
does anyones car randomly shut off? BtownSTG3 2005 - 2010 24 May 7th, 2010 07:53 PM
HELP!! - Car quits randomly and won't restart tjf9389 5.0 Mustangs 6 May 7th, 2010 05:04 PM
wipers randomly start! unblock 99-04 13 February 6th, 2009 08:57 AM
Car runs fine. Is this code bad? Muscletang 96-98 3 May 5th, 2008 08:00 PM
Help Car Randomly Stalls? chaosstangman 5.0 Mustangs 4 November 17th, 2007 11:12 AM
