Look Ma! My First Post!
AC,shifting,stereo questions.
Well, I have a 1994 Mustang GT with around 169k miles.
It is my first car. I am in love ![]() Well the previous owner installed an aftermarket stereo and completely like fucked all the wires so now only the very back speakers work. It kind of sucks, should I take this to a pro? ![]() Since I have had the car I have replaced the Distributor,starter, and serpentine belt. Along with 2 routine oil changes. Well anyways, My windows are kind of failing now. They like go up to a certain height(every time it is different) and make this weird noise and then I have to pull it up. Any ideas on how to fix? Also My Car runs really hot. It says "normal" on the gauge but it pushes to M all the time. The A/C is broken (shoots air but not cold). I am thinking it is possibly a Thermostat problem? One last thing, When I shift through the gears sometimes I have to push the gearshift really hard into the gear, mostly first and reverse does this. And when I am puttin along I go from 1-2-3-4- and then If I shift at 2000 rpms I get this gross ping put ping ping noise and it keeps going and I don't really accelerate fast untill I reach 55. So I usually just shift out of 4th to 5th at around 2500 but is this a serious problem? Tell me what I need to fix so I can make a parts list. Thank you so much!
Well your gear problem is a synchro problem or a clutch problem. Take it to a transmission shop and get it looked at. i had the same problem in my other stang. you may just need to charge the ac with r134(or 5 forget which one)a coolant.
i would change the thermo stat and check your water pump. If it looks old replace it. you can run new wires to your front speakers. shouldn't be that hard. |
#3 | ||||
The AC may just need to be recharged with new refrigerant. I doubt that the t'stat is a problem.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Threads Similar to: AC,shifting,stereo questions.
| Assorted Stereo Questions | Brettva | Audio/Video | 20 | March 11th, 2010 11:31 PM |
| Power shifting questions | Odin | 2005 - 2010 | 33 | June 7th, 2009 03:28 PM |
| Need help with a few STEREO questions with my 2008 GT | warrior86 | Audio/Video | 3 | May 13th, 2009 04:23 PM |
| stereo system questions | 01dutchGT | Classic Mustangs | 16 | September 3rd, 2008 12:25 PM |
| Mach Stereo questions | TheManInBlack | Audio/Video | 0 | November 24th, 2006 04:22 PM |
