Air condition blows warm
Old July 17th, 2010, 08:34 PM   #1
Foxmoto28's Avatar
'94 GT Coupe
Foxmoto28 is on a distinguished road
So I currently have all stock cooling system in my '94 GT.
I bought an aluminum 3 row radiator and am waiting for it to arrive.
My problem is when I start up the stang the A/C will blow somewhat cold but not as powerful nor as cold as I want it to. Radiator is constantly full of water+antifreeze.
I live in Texas, so heat is not a concern here haha.
When I get my radiator installed (also replacing the thermostat) will my problem be fixed or am I looking at replacing the blower or something like that?
I need a list of things to look at for a fix.
Also, back when I was driving my '83 bronco I had a A/C problem and bought a refrigerant kit for the lines but never used it. How do you tell if the coolant level is good in the lines so I don't put too much, if I decide to use it.
Old July 17th, 2010, 11:57 PM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
It sounds like your AC system might need to be recharged with refrigerant.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old July 18th, 2010, 12:55 AM   #3
Foxmoto28's Avatar
'94 GT Coupe
Do you know where the orifice tube is located? I'm thinking about replacing it before I recharge.
Old July 18th, 2010, 08:20 PM   #4
Foxmoto28's Avatar
'94 GT Coupe
I cannot seem to find what psi is needed for my system; does anyone know?
Old July 20th, 2010, 03:44 PM   #5
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
your rad has nothing to due with your a/c you need to get it charged with uv dye in it so that if there is a leak you or the tech that recharges it can find the leak with a black light
Old July 20th, 2010, 03:49 PM   #6
94bossgt's Avatar
94 mustang gt
too slow to tell
your car empty takes 34 oz to fill
Old July 21st, 2010, 05:37 PM   #7
Silver281gt's Avatar
1998 mustang gt
14.4 @ 95
Silver281gt is on a distinguished road
Send a message via Yahoo to Silver281gt
Mine blew cold as heck... Parked it thursday and sarted it monday and now it blows hot as heck.. Texas hot that is..
1998GT with SLP mufflers.. 4R70W
Bassani O/R X,SLP LoudMouth 1 Dumped
DiablowSport Predator
4.30 gears
Old July 24th, 2010, 07:33 PM   #8
Foxmoto28's Avatar
'94 GT Coupe
I thought it had something to do with the engine getting hot causing the a/c to loose its juice. Thanks for clearing that up.
I have the kit to get it recharged; plan on getting it done this weekend.
Old July 25th, 2010, 12:04 PM   #9
Autotech's Avatar
Autotech is on a distinguished road
I found the A/C pressure line that runs along the passenger side frame rail got to hot and busted after I installed 1 5/8 headers. I bought a new line from the factory and installed it upside down to keep it away from the headers, fits well and does not get in the way of anything like this.
It is good to use a vacuum pump to remove any air form the system before you temp to recharge it. Air Conditiong Troubleshooting and Repair Diagnostics
www.freeautomechanic.com
Old August 31st, 2010, 08:45 PM   #10
Foxmoto28's Avatar
'94 GT Coupe
Where is high and low side?
Here's an awesome side to doing it. I found out that there's a screw on one of the sides (next to the air filter/radiator) and it was siliconed on. I'm not sure what to think about this?
Old August 31st, 2010, 08:56 PM   #11
94 v6 mustang
Puffy93 is on a distinguished road
there is no high or low side with r-134, that's only on r-12.
Old August 31st, 2010, 09:42 PM   #12
Foxmoto28's Avatar
'94 GT Coupe
How can I tell if it's never been serviced? The guy who owned it before me didn't do too good of a job caring for the car.
Old September 1st, 2010, 12:20 PM   #13
94 v6 mustang
there really isnt a definitive way to tell if its been serviced or not, if it liiks cleaner than the rest if the area or was marcks where a tool might have scratched or dented it then it has probably been serviced. after a couple years cars tend to lose their freon slowly so more than likely it just needs a recharge
Old September 1st, 2010, 01:20 PM   #14
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
WRONG WRONG WRONG!!!!!!!!!! Not trying to be an ass, just being brutally honest so no one reads what you wrote and taps into their high side port.
There is a high side and a low side. There HAS TO BE because that's how an air conditioner works. If there is no high/low side, the pressure is the same for the whole system. If the pressure is the same on the whole system, there's no way to cool the fluid. The whole thermodynamics of an A/C system don't work that way.
The fluid from the compressor to the expansion valve is considered high side (b/c it has high pressure). The expansion valve allows the fluid (R-12 AND R-134a) to expand and drops the pressure (and temperature). The fluid from the expansion valve back to the compressor is considered low side.
Somewhere on your car, there are two service ports. One is for the high side and the other is for the low side. The DIY recharge can will ONLY fit on the low side port. You don't want to mess with the high side port. You also need the compressor to be kicked on for the DIY recharge can.
Old September 1st, 2010, 03:36 PM   #15
Foxmoto28's Avatar
'94 GT Coupe
That didn't sounds right to me about no side differences. I'm still not sure which one is which and the guy at the part store was confused himself
Old September 1st, 2010, 03:48 PM   #16
Moderator
2003 Grand Cherokee
I can not speak specifically for your car as I don't have anything to look at. The high side port is usually between the dryer (canister about the size of a coke can) and expansion valve (usually near/on the firewall).
The low pressure port is usually pretty close high pressure port. The line it's on goes from the firewall to the compressor.
Old September 1st, 2010, 09:52 PM   #17
ryanw's Avatar
1991 Ford Mustang GT
PEOPLE IF YOU DONT FIND AND FIX YOUR FREON LEAK YOUR GOING TO HAVE TO RECHARGE YOUR SYSTEM ALL THE TIME. IM ALSO AN A/C SERVICE TECH, BUT FOR SINGLE AND MULTI FAMILY HOMES. WHEN WE HAVE A LEAK WE PRESSURE TEST OUR SYSTEMS WITH NITROGEN AND SOAP UP ALL FITTING UNTILL YOU FIND THE LEAK. HOPFULLY YOUR LEAK IS AT ONE OF YOU CONECTIONS AND NOT IN YOUR E-VAP COIL. BUT AFTER FIXING YOUR LEAK YOU NEED TO PULL A VACUUM. IF YOUR SYSTEM WAS EMPTY OR IF THERE ANY THING ELSE IN THERE BESIDES FREON. IM NOT SURE IF THATS HOW YOU FIND A LEAK IN AN AUTOMOTIVE A/C. IM SURE THE LAST GUY THAT COMMENTED KNOWS......
Old September 2nd, 2010, 01:25 AM   #18
ryanw's Avatar
Look for signs of oil on or near all A/C conection
Threads Similar to: Air condition blows warm
split room air condition help obdnanr The Clubhouse 2 May 2nd, 2010 01:50 PM
Length of belt for air pump and condition delete? bansheex 94-95 3 March 30th, 2009 12:46 PM
this blows Onemanzu The Clubhouse 5 January 16th, 2009 10:50 PM
air condition help droppedbass87 5.0 Mustangs 9 July 25th, 2007 02:52 PM
air condition question warrior86 V6 Mustangs 3 May 16th, 2007 06:00 PM
