1994 Mustang GT
![]() iTrader: 2 reviews
twin turbo kit
i just purchase a twin turbo kit for my 94 5.0
i got the intercooler, seals, gaskets, headers, and the turbos. t3/t4 i am making the piping for it. i am getting the neccesary items to run it and control it (mas air, throtle body, regulators, etc.) but its still going on a stock 5.0 for the most part. so mostly cam and heads i do plan on upgrading the heads soon. any suggestion on to what will help this turbo out the best? i figured gt40x heads wouldnt be bad for this, does any1 have any suggestions to add to just give me ideas. this is more of a project to see how it comes out. ive never heard much about sn95 twin turbos so i thought it would be cool to build on.
![]() 1994 Mustang 5.0 |
I assume you are talking about the Ebay twin turbo kit?
If so, bolt the manifolds on and mount the turbo's. Then try to hut your hood. Oh and, make sure you do this before buying anything else.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1994 Mustang GT
first off y? wanna just tell me?
i have a 2 inch cowl hood if heigths the problem. its not from ebay either...
most turbo kits built for the SN-95 are actually just re-tagged foxbody systems. Many people have reported severe hood clearance issues (you cowl wouldnt help) and others have had problems with the turbo's sitting where the P/S and Alt are.
SO im just suggesting that you double check those issues BEFORE you get too involved in buying more parts
1994 Mustang GT
i was going to run it down, probably right behind or by the bumper bracket. im making all the piping for it so ill make sure i can secure the turbos in spot where i where have plenty of clearence. thanks for the heads up though. im even moving the battery in the trunk to try to clear some of the room too.
#6 | ||
88Notch 10.59 @132 / 03 Mach 1 13.1 @104
Who needs power steering and ac.... I havent missed mine one bit even in the heat.... And on leather seats... BUt those will soon be cheapo summit racing seats haha
Military Crew USMC
#7 | |
I'd like to see pics of the hardware - a twin turbo setup sounds good!
1995 GT 5.0 manual trans. 70K. Stock. |
1982 GT t-top
no proof of purchase
he can run his exhaust to wherever he wants to mount the turbos they dont have to bolt directly to the header
1994 Mustang GT
i figured in the end it might be easier and better spots to mount the turbos and fabricate to them. otherwise yes i could see many clearence and space issues by just mounting them.
i still need to start clearing things out so i can start the fabricating, i just need to find time when im not driving it so often, so probably not for a month or so cause its too nice right now not taking my car out. i wouldnt want to rush something like this. better take my time and do it right first time around.
sounds like a good plan! good luck man
![]() BBK fender well cai, Mach 1 Rims, Accel ignition system, Steeda triax short throw, Venom 400 performance module, gt40 intake, 24lb injectors, 76mm mas |
98 GT, 93 Ranger!
well there goes my chances of my car being faster then yours
sounds like a fun winter project
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1995 Mustang GT
I would go with AFR heads over the gt40x heads
Threads Similar to: twin turbo kit
| Twin turbo kit or Supercharger kit? | white08mustangv6 | 2005 - 2010 V6 | 45 | September 7th, 2009 04:38 PM |
| twin turbo kit | myPONYisHARD | V6 Mustangs | 7 | November 24th, 2007 10:15 PM |
| Turbo HorsePower Twin Turbo kit | dblindberg | 2005 - 2010 | 34 | June 17th, 2007 08:05 PM |
| Twin Turbo Kit.. | Cesar2cool | V6 Mustangs | 0 | June 1st, 2007 11:40 AM |
