ECU dead??? How do you know?
Old March 25th, 2007, 08:53 PM   #1
Look Ma! My First Post!
rnrdthefox is on a distinguished road
I've got a project car (actually an early bronco) that I have transplanted an Explorer engine and 94-95 mustang ECU and harness into. I just got it up and running and was pulling KOEO codes as I'm not ready to fire the engine. I have cleaned up all the codes except for one regarding the purge cansister.
Long story short, I pulled the positive terminal off the battery to run some errands and later returned to hook up the purge canister solinoid. I hooked both it and the battery back up.
When I turn the key, no pumps, self test or anything. It's like the ECU isn't turning on. I've checked the pwr and gnd connections and everything looks good.
Any measurements to the ECU that I can do to see if I fried it???
thanks.
Threads Similar to: ECU dead??? How do you know?
MM is dead!!!!!!!! MSO The Clubhouse 17 September 14th, 2007 08:14 AM
MM is dead.. again MSO The Clubhouse 34 August 25th, 2007 10:34 AM
MM dead? MSO The Clubhouse 130 August 13th, 2007 01:02 PM
Car dead? HessiaN257 Modular Mustangs 6 July 30th, 2007 01:22 AM
Is he dead? turp The Clubhouse 43 June 28th, 2007 07:53 AM
