clutch noise
Old July 30th, 2010, 03:08 PM   #1
InSaYnE is on a distinguished road
clutch noise
so in my 94 gt 5 speed i noticed some clutch squeak or squeal its a constant noise almost sounds like a light metal to metal rub. when you rest your foot on the petal a little bit it goes away. so i replaced the throw out bearing and the the pilot bearing annnnnnnnnnnnnnnnd the sound is still there. any suggestions? i noticed my brothers 94 and 95 before it both had this issue.
Old July 30th, 2010, 03:59 PM   #2
1995 Mustang GT
Thlad is on a distinguished road
Send a message via MSN to Thlad
I have the same problem but I havent tried to fix it yet. Did u put a new bearing retainer in? I remember reading something about putting a new one in when u do the bearing... anyways good luck with it.
BBK fender well cai, Mach 1 Rims, Accel ignition system, Steeda triax short throw, Venom 400 performance module, gt40 intake, 24lb injectors, 76mm mas
Old July 30th, 2010, 04:56 PM   #3
retainer on the pilot? if so the new pilot came with it so i installed it
Old July 30th, 2010, 06:25 PM   #4
1995 Mustang GT
throw out. they changed it to a metal sleeve instead of aluminum cuz the aluminum wore out to fast and could gouge... thus causing the noise
Here is one from summit
Ford Racing M-7050-B - Ford Racing T-5 Bearing Retainers - Overview - SummitRacing.com
Old July 30th, 2010, 06:48 PM   #5
No I didn't know anything about it guess I get to drop the tranny again
Threads Similar to: clutch noise
Clutch noise? New clutch install mtbr101 99-04 0 December 8th, 2009 11:08 PM
clutch noise? Lind 5.0 Mustangs 3 June 19th, 2009 05:04 PM
clutch noise. Codeman V6 Mustangs 19 April 6th, 2009 11:54 PM
clutch noise ehfrenchy21 99-04 9 July 27th, 2008 03:36 PM
clutch noise? captain_communism 99-04 2 September 22nd, 2007 11:11 PM
