mass air sensor question - Forums at Modded Mustangs
post #1 of 21 Old July 31st, 2010, 08:52 PM Thread Starter
hey guys i just need to know if a mass air sensor that works for a 1993 5.0 will work for a 1994?? or is the differences? it is a different part number as stores.... but they've been wrong before
thanks for any help
autoarc94 is offline
post #2 of 21 Old July 31st, 2010, 09:09 PM
Send a message via MSN to Thlad
no im pretty sure they dont
BBK fender well cai, Mach 1 Rims, Accel ignition system, Steeda triax short throw, Venom 400 performance module, gt40 intake, 24lb injectors, 76mm mas
Thlad is offline
post #3 of 21 Old August 2nd, 2010, 06:27 PM Thread Starter
does anyone know if this is the original 94' 5.0 mass air meter?? i was told its out of a 89'-93' by C&L
thanks in advance for info
post #4 of 21 Old August 2nd, 2010, 07:15 PM Thread Starter
ok well, i found that the part number is from a 1993 5.0 would this cause the idle to dance and chug?? should i now check my cars computer to make sure nobody swapped it ?
i need help here, i'm trying to buy a c&l 76mm maf but they reuse the sensor that i would have, so if this isn't originally from the car, it may not work correct??
post #5 of 21 Old August 3rd, 2010, 06:17 PM
Send a message via AIM to AdderMk2
don't buy a C&L. they are complete crap. save your money and buy a maf that is actually worth a damn.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
AdderMk2 is offline
post #6 of 21 Old August 4th, 2010, 08:09 PM Thread Starter
what would you recommend?? i just like their recalibration tubes, seems like a solid way to upgrade... but i'm lookin for an 80mm with 30 injectors
post #7 of 21 Old August 4th, 2010, 09:29 PM
recalibration is great if you are going to be swapping injectors on a daily basis. Otherwise, I prefer to use OEM ford electronics.
Great example... the 80mm Cobra maf.
but then again. I have access to tuning and can swap out whatever parts I want, whenever I want.
[SIGPIC][/SIGPIC]
AdderMk2 is offline
post #8 of 21 Old August 4th, 2010, 09:36 PM Thread Starter
k good point on the daily basis thing, would a 80mm cobra maf from a 93' work on our cars? or at least a 94? i had seen some on craigslist near me, but he only specified up to 93 but also said it works for 4.6's .....that made me question it
post #9 of 21 Old August 4th, 2010, 11:18 PM
*facepalm* idk why I put myself through this.
for starters, the 93 cobra had a 70mm maf, so did the 94-95.
the maf you would want is from a 99+
[SIGPIC][/SIGPIC]
AdderMk2 is offline
post #10 of 21 Old August 5th, 2010, 08:21 AM
Resident Headbanger
Bullitt95's Avatar
I have the C&L 76mm MAF that's calibrated for 19lb injectors and it works just fine. Needless to say I'm also running the stock injectors.
2006 GT - 5MT - 310rwhp 328rwtq - 12.67 @ 108.61 - Mod List
Sold: 1995 GT Green, 1995 GT Red
Bullitt95 is offline
post #11 of 21 Old August 5th, 2010, 09:08 AM
and making stock-ish HP.
lets just say the C&L didnt fare too well on my 347 stroker. Nor the 95 GT i was tuning... or the 92LX that I did a head swap on.
I wouldn't wish a C&L on my worst enemy.
[SIGPIC][/SIGPIC]
AdderMk2 is offline
post #12 of 21 Old August 5th, 2010, 12:43 PM Thread Starter
haha ok, well here's another question i'm sure you'll like adder... how would i get that maf to work? and nonetheless, i appreciate you guys at least helpin me out!
oh, an i wasn't sayin the 80mm was from the 93, it just says it'll work for that year, i'm guessing that just means it would need modified....
post #13 of 21 Old August 5th, 2010, 05:50 PM
95opal's Avatar
If you know the MAF transfer rate for the meter and have access to the ecm you can pretty much make any meter work. If your refering to the C&L for a fox its just a mater of getting the correct sample tube. The problem with the c&L meters is they arent very accurate and have been known for reaking havoc on modified cars.
95opal is offline
post #14 of 21 Old August 5th, 2010, 09:19 PM Thread Starter
well thats good to know, glad i didn't fork that money out yet, but pretty much i've got a dss 306 with afr 185's and an x303 cam, i'm converting it from carb to fuel injection with a different car, i've already got the trickflow track heat upper and lower, and a pro products 75mm throttle body, i just really need healthy injectors and a maf to take it, again, my plan is to try and find 30's with an 80mm sensor anyone got an idea of where to get a matching set for a decent price??
post #15 of 21 Old August 5th, 2010, 11:16 PM
get a PMAS calibrated for 30's and youll be all set
[SIGPIC][/SIGPIC]
AdderMk2 is offline
post #16 of 21 Old August 6th, 2010, 12:15 AM Thread Starter
i'm sure i'll regret asking this, but what does PMAS stand for??
post #17 of 21 Old August 6th, 2010, 04:46 AM
95opal's Avatar
PMAS is basically PRO-M .......when they went out a few years ago some of the top guys started a new company. Pretty much a PRO-M in a round about way
95opal is offline
post #18 of 21 Old August 6th, 2010, 09:41 AM Thread Starter
oh i gotcha, i thought it stood for something in particular, not a company
post #19 of 21 Old August 6th, 2010, 06:36 PM
Did anyone ever notice that alot of the "dumb questions" can be answered with google....
Google
[SIGPIC][/SIGPIC]
AdderMk2 is offline
post #20 of 21 Old August 6th, 2010, 07:27 PM Thread Starter
ya, for buying things, not too much reliable info though, imo thanks for yours though
Human Verification
