Hardon Enflooziast
Noisy fuel pump
Yup, just what the title says. And its more than just the noisy humming sound, its different now, like a buzzing sound coming from the rear of the car, almost like its sitting against something and vibrating. Any thoughts?
![]() Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines, |
Hardon Enflooziast
Really? No ideas? Sad day.
But I think that is normal as i do believe our stangs run electric fuel pumps and that buzz is just the pump working. So when you don't hear that sound that is when you need to worry.
1994 Mustang GT
mine makes the exact same noise... and if you run it really low on fuel to where its about to run out it gets alot louder
Hardon Enflooziast
I actually narrowed down the sound, it wasn't the fuel pump but a hum coming my left rear speaker. I'm thinking it has to do with the fact I wired an aftermarket deck to the Mach 460 system.
Hardon Enflooziast
Indeed. That's what happens though when you use a shitty walmart wiring harnesses...one of the pins that are in the female plug for the speaker connectors ended up pushing out the back.
Threads Similar to: Noisy fuel pump
| Datalogging Fuel Pump Volts with a BAP and Fuel Flow Rates | Trick Tuners | 99-04 | 21 | November 18th, 2010 08:44 PM |
| Boost-A-Pump or GT500 Fuel Pump? | stanglifemike | 2005 - 2010 | 64 | September 21st, 2009 01:17 PM |
| Fuel pump question. Stock GT pump to GT (supercar) pump. | Nate's4.6 | 99-04 | 15 | May 14th, 2008 02:25 PM |
| Suggestions on Fuel Cell's & Fuel Pump | bstang | 2.3 Mustangs | 5 | January 21st, 2008 09:04 AM |
