95 GT Intake question
Old August 19th, 2010, 10:10 PM   #1
lilj4u2njoy is on a distinguished road
im doing a Cobra clone on my 95 GT and i was wondering will a intake manifold from a 94-95 cobra work with my 95 gt? without major modifications?
Old August 19th, 2010, 10:13 PM   #2
92Notch's Avatar
1996 Cobra
Not fast enough.
92Notch is on a distinguished road
It should bolt on like any other intake...
Mods: Full 01 Cobra drivetrain (Teksid block ) T56, 3.73s, Pro 5.0, Aluminum driveshaft, JLT CAI, BBK O/R X, SLP LM1s, Full welded in sub frame connectors
Old August 20th, 2010, 12:52 AM   #3
bradtheblade's Avatar
1995 cobra
slow show car
bradtheblade is on a distinguished road
it is a direct fit upgrade oem part
Old August 20th, 2010, 01:59 PM   #4
thanks for the help, i found a nice one thats for a 93 5.0 but thats the same thing correct? should still work
Old August 20th, 2010, 04:57 PM   #5
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
its NOT the same thing. The EGR spacer that the foxes normally use, is actually built into the 93 manifold. For your emissions parts to line up, you will have to get an adapter elbow to bolt between the intake and the TB. At which point, your EGR valve will be sitting too far off to the passenger side.
I would strongly suggest you avoid the 93 cobra intake if you arent sure what you are doing with the swap. Which it seems like you arent.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Threads Similar to: 95 GT Intake question
one last intake question sonicblue 99-04 13 April 7th, 2010 12:42 PM
non-pi intake to PI intake alum. crossover question ndfrspd 96-98 2 May 29th, 2009 05:47 PM
Intake Question ncsubowen V6 Mustangs 32 May 24th, 2009 08:29 PM
intake question burin_rubber V6 Mustangs 20 March 23rd, 2008 01:09 AM
gt-40 intake question NOSLO5.0 General Tech 0 December 27th, 2007 12:48 PM
