whats the smog pump for and do i need it? - Page 2
Old September 3rd, 2010, 06:17 PM   #21
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
Originally Posted by lucky5.0 View Post
So, let me get this right, to delete my smop pump & a/c i need a smaller belt (6PK2100) 82.7" long? Also, I need to plug the holes on the back of the heads with 5/8-11 bolts, no more than 1'' long. Correct?
you should check the belt size before buying. use a piece of string and measure the belt route.
and yes, two 5/8"-11x1" bolts. It is strongly suggested to use carb cleaner and a battery terminal bottle brush to clean the threads in the head before trying to insert the bolt.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old September 3rd, 2010, 06:25 PM   #22
lucky5.0's Avatar
Last of the 5.0
TBA
lucky5.0 is on a distinguished road
^^^you Rock
show me boobs
Old September 14th, 2010, 09:29 PM   #23
Look Ma! My First Post!
1stang95vert50 is on a distinguished road
Originally Posted by Bullitt95 View Post
Mine are Roush side skirts and the car already had them on when I bought it.
I did that with a pair of old spark plugs. They fit perfectly. Just make sure you add thread sealant.
You'll need a belt that's about 82.7" long (6PK2100). I'm also going to remove my AC compressor 'cause it has an internal leak (worn seals).
i dont know how u could use a 82.7 belt . i just tried about 20 belts on mine ( i started at 82.7 ) ended up useing a 95 1/8 from oreily ..masterpro k060945----6k945 . im runing ac and no delete pulley
Old September 14th, 2010, 09:49 PM   #24
different routing
[SIGPIC][/SIGPIC]
Old September 15th, 2010, 04:07 AM   #25
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
The 82.7" belt is for the smog pump AND AC delete. Here are my belt routing diagrams:
243.5rwhp/284.2rwtq
Mod list in My Garage
Old September 15th, 2010, 09:55 AM   #26
Its funny how specific that list if about belt sizes. because I myself run the alt, idler, P/S, WP, crank and tensioner... and my car uses a 80.5" belt
[SIGPIC][/SIGPIC]
Old September 15th, 2010, 01:52 PM   #27
Bullitt95's Avatar
13.546 @ 105.32
The quoted belt sizes assume stock pulleys and they're meant to be a guide. One problem is that many of us, including myself, run various combinations of underdrive pulleys so it's still down to the measuring with a piece of string method to find the correct length. Another problem is that there are slight variances in belt length between manufacturers even if the belt size is supposedly the same.
FWIW, I'm using a 79.5" belt (6PK2020) with the same AC/smog delete routing and the tensioner nearly bottoms out. I have an ASP crank pulley but the others are stock.
Old September 15th, 2010, 04:45 PM   #28
im running stock pullies.
[SIGPIC][/SIGPIC]
Old September 15th, 2010, 08:16 PM   #29
meh
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
I used 9/16" bolts as per this guide... I had to run a tap through mine to get all of the carbon out before I could get the bolts in. I happened to have the engine out of the car, so it was pretty easy to do...
A great guide from Allfordmustangs.com in PDF format for the 94-95 5.0 Mustangs... its pretty much the same for the Foxes.
http://www.allfordmustangs.com/techarticles/Smog2.pdf
'87 2.3 Notch with +4 cylinder mod
Ass, Cash, or Grass.. nobody rides for free
Black Stang Crew Member #11
Old September 15th, 2010, 10:28 PM   #30
that page is wrong.... end of story
[SIGPIC][/SIGPIC]
Old September 15th, 2010, 10:53 PM   #31
meh
Notcho's Avatar
You're right; everywhere I search it says 5/8".
But now that I think about it, I used bolts I had in one of my junk boxes. After I cleaned the threads, I just tried bolts until I found some that fit, then put a few washers on them so they wouldn't bottom out.
Old September 15th, 2010, 11:20 PM   #32
Here's a pic that I took a few years ago when I was building my engine. These are the inserts needed to adapt the 5/8" hole down so that the alternator and power steering can bolt up. You know... since the heads are able to be used as a right or left head.
anyway...
[SIGPIC][/SIGPIC]
Old September 18th, 2010, 08:41 PM   #33
fogged306's Avatar
89 GT
Just FYI because I haven't seen it posted (unless I missed it), but if you're keeping your stock cats, be warned that you may have issues with them clogging after a while with no smog pump. The air injected into them from the smog pump encourages light-off in the cats. without the extra oxygen being pumped into the system, the cats will eventually clog. Depending on the current shape of your cats, this may take a while, or it might happen sooner than you want.
Old September 19th, 2010, 09:01 PM   #34
408gt91's Avatar
408gt91 is on a distinguished road
Get an h pipe.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old September 22nd, 2010, 11:12 AM   #35
1991 mustang GT
14.12@99.89
91_FOX is on a distinguished road
i just took off my airtube on the back of the heads sunday night. prolly one of the hardest things ive done on that car so far. If your car has a firewall clutch adjustment and A/C you might as well add another hour to this process driver side was the worst. and thank you "AdderMk2" for the bolt size's they worked great
306, gt40x heads, msd ignition, gt40 intake, 75mm throttle body, 30lbs injectors, hooker shorties xpipe flowmaster 40 series,... SOLD.
Old October 6th, 2010, 09:51 AM   #36
beamer814's Avatar
1990, GT, 5 speed
I Dont Wanna Know :(
beamer814 is on a distinguished road
this seems like a really common mod i wonder why no ones done a build thread
Arguing with someone on the Internet is like participating in the Special Olympics...Even if you win you are still retarded!
Threads Similar to: whats the smog pump for and do i need it?
Smog pump/ Air pump?? tutman900 5.0 Mustangs 28 October 18th, 2009 07:28 AM
smog pump imported_Gt_Jay 5.0 Mustangs 15 February 7th, 2008 02:09 PM
Smog pump help yellowgt5 5.0 Mustangs 4 May 4th, 2007 03:48 PM
Smog Pump jcc1991 5.0 Mustangs 3 September 4th, 2006 11:51 AM
smog pump cali 5.0 5.0 Mustangs 3 July 24th, 2006 01:03 PM
