power steering pump
Old August 26th, 2010, 03:44 PM   #1
1994 mustang gt vert
n/a
autoarc94 is on a distinguished road
power steering pump
hey guys, how in the world do you get the power steering pump off the bracket, if i am correct the pulley is pressed in ?? and either way i can't get to the little hex looking bolt under the pulley! i need help......
i just need to clean everything before i put my motor in and this is the last component
thanks in advance!
Old August 26th, 2010, 06:47 PM   #2
Mirg94GT is on a distinguished road
You have to use a power steering pulley puller and installer. You can usually get them at an Auto bone or parts store they rent them for free with a deposit. Make sure the bolt that threads into the pulley is right and threads in a good ways.
Old August 26th, 2010, 08:34 PM   #3
n/a
thank you! that was what i figured
Old August 27th, 2010, 07:59 AM   #4
no prob!
Old August 27th, 2010, 12:12 PM   #5
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
in my own experience changing mine was a pain in the ass...do not get a pulley puller from advance or auto zone cuz they are junk and break easy...and try not to bend the power steering pressure line or you will have a leak that you wont be able to fix unless you replace the line..god luck
Old August 27th, 2010, 02:41 PM   #6
95RED5.0's Avatar
1995 Mustang GT
95RED5.0 is on a distinguished road
so thats why mine leaks! Thanks orangestang
Old August 29th, 2010, 08:59 PM   #7
1995 Mustang GT
no problem,
Threads Similar to: power steering pump
power steering pump davidstivers09 V6 Mustangs 0 May 24th, 2010 12:40 AM
Power steering pump Chris951 5.0 Mustangs 17 August 21st, 2009 12:03 AM
67 power steering pump lord7 Classic Mustangs 1 September 25th, 2008 10:36 PM
Power steering pump? Killax15 99-04 5 June 21st, 2008 12:56 PM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
