Anyone swapped their 94-95 computer for a fox computer?
have major tuning issues...apparently these cars are known for this...found a computer from a 93 for $50...my tuner said this is probably my best bet to get it fixed..finally...and to avoid future issues when the super charger goes in.
Thoughts??? Anyone have first hand experience?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
swapping out to a fox ECM is a bandaid fix to a simple problem.
I see nothing in your mods list that cannot be handled by the SN-95 ECM
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
suggestions? i either get a hanging idle, or it idles down too quickly and dies...myself and my shop have tried just about every thing we can think of..adjusted throttle body, TPS, IAC, SCT tune changes etc etc...no vacuum leaks that we can tell of...
your "shop" is clearly missing something. Either bring the car somewhere else that actually has a clue, or pick up a Moates Quarterhorse and tune it yourself.
My 11.25:1 347 stroker idles like it stock. I have actually had alot of people ask me why my car was idling so low.. And when I asked... you think 750 is low? they reply.. "How the hell? My car idles at 1100!" Your tuner needs to set the TB airflow values, you need to ditch the C&L maf, and its recommended that they set your car to run in OL at low rpm. Tuners that dont know, have a bitch of a time tuning for LT headers. They actually do make the tuning process difficult.
#5 | |
what do you have/suggest from your throttle body forward ie CAI, MAF?
n/a
Many people do switch to a fox comp.
TRUE BLUE CREW MEMBER #4
1996 Mustang 5.0
14.0
I have the same issue,the car takes forever to come back to throttle..
![]() A Ricer is a stupid young idiot who thinks he is a car expert after watching The Fast and the Furious, Pimp My Ride, and playing Need For Speed Underground-LMFAO |
i'm running a 90mm accufab TB, 4" custom CAI, and 90mm lmaf
Ok...so i have almost decided to go get a Moates and start tuning this turd myself...i read up on tons of shit last night and think i should be able to pick this up and get it right...
question is what happens to my SCT that i have? Do i completely remove and sell? I have up to 7 programmable tunes for my sct, can i use this cable for the Moates and store different tunes? What will the Maotes let me do that the SCT will not? Thanks.
What tuning software do you suggest to use with the Moates? Most intuitive and user friendly...
I use the quarterhorse myself. Make sure you get a wideband or you REALLY wont be getting anything done.
Remove your SCT and try to sell it. You will likely end up trashing it.
Threads Similar to: Anyone swapped their 94-95 computer for a fox computer?
| will COMPcams Xtreme Energy 266 work with stock computer? FOX | Smoked88GT | 5.0 Mustangs | 16 | May 1st, 2010 03:06 PM |
| 94 cobra computer into a fox | mustanglx90 | 5.0 Mustangs | 0 | July 9th, 2009 08:51 AM |
| Is An 93 5 Speed Computer The Same As An 89 A9l Computer?? | e3sean | 5.0 Mustangs | 4 | February 4th, 2008 07:40 PM |
| fox body computer problems | 1TITAN | 5.0 Mustangs | 3 | October 7th, 2007 01:43 AM |
| 1990 f150 5.0l Swapped to a Fox | dStoltenberg | 5.0 Mustangs | 13 | January 28th, 2007 10:58 PM |
