1994 Mustang GT
Water Pipe Gasket?
I took my water pipe (that the radiator hose connects to) off, and the gasket just peeled off. I went and got another one at autozone and put it in, and it is leaking HORRIBLY. Do I need more than one gasket? Or should I just seal it shut with quiksteel?
use a little Permatex® Black Silicone Gasket along with a new gasket from autozone..should be fine..although i bought a cheap ass chrome one that would leak no matter wtf i did...
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
you need to remove all of the old gasket material off, clean both surfaces very good.
then use BLUE permatex, not black. along with anew gasket.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
Threads Similar to: Water Pipe Gasket?
| Gasket Between Headers and H-Pipe? | RKBA | 5.0 Mustangs | 7 | September 2nd, 2010 11:08 AM |
| Gasket between header and H-pipe? | motodanb | 94-95 | 2 | August 7th, 2010 07:13 PM |
| Update on Blown head gasket/water leak | vinsanity2701 | 5.0 Mustangs | 22 | July 14th, 2010 04:55 PM |
| intake manifold gasket or head gasket? | rasalibre | 5.0 Mustangs | 5 | November 26th, 2008 05:37 PM |
| car wont stay on, oil in water, blown head gasket?? | 94pacecarSVT | 99-04 | 9 | August 5th, 2008 08:20 PM |
