ac vacume leak
Old September 4th, 2010, 12:20 PM   #1
95 mustang gt
Blackedoutgt is on a distinguished road
ac vacume leak
ac is only blowing out defrost vents, im pretty sure its a vaccume leak.
my queston is, how do I find it?
-95 gt
Old September 4th, 2010, 07:53 PM   #2
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
there is a black hard vac tube that comes through the firewall near the AC ports that pass through. (rear left side)
Follow it over to the vac tree at the right rear of the engine bay. Find where its broken.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old September 4th, 2010, 09:25 PM   #3
95 mustang gt
Found it. pretty much cut in half. thanks for the help ^^
I tryed to get the small plastic vaccume line at autozone but they said they didnt have it. anyone know where I can buy this?
Old September 4th, 2010, 10:03 PM   #4
use rubber vac line and slide both sides of the broken line into it.
[SIGPIC][/SIGPIC]
Old September 4th, 2010, 10:36 PM   #5
95 mustang gt
im thinking about just running a whole new vaccume line. just because i dont want to keep messing with it if it wants to break again.
Do you know what size line id need?
Old September 4th, 2010, 11:06 PM   #6
just do what I said, and leave it be. I had the same problem (hence knowing where it was broken) and repaired mine the way I told you. That was 5 years ago.
[SIGPIC][/SIGPIC]
Old September 4th, 2010, 11:14 PM   #7
95 mustang gt
alright ill try your method. I appreciate the help man
Threads Similar to: ac vacume leak
fixed vacume leak and now it runs like poo 95project 5.0 Mustangs 11 May 19th, 2010 10:22 AM
vacume leak tungstang 2005 - 2010 5 August 16th, 2009 03:44 PM
What vacume line can be removed orangesaleen89 5.0 Mustangs 0 July 8th, 2009 08:47 PM
65 289 Vacume Advance issue Rolfey Classic Mustangs 2 May 26th, 2008 06:51 PM
vacume line greyauto02 V6 Mustangs 8 November 3rd, 2007 04:43 PM
