95 mustang gt dies out
hey guys... i have a 95 mustang gt theres no modification done to the car, eveything is stock...
the problem with the car is it dies out wen im at the stop sign or stop light. so the rpm goes back and forth in between 0-1 goes back and forth then it dies out after doing that i jus changed the cap and rotor yesterday... sooo plzz help |
Three things you can do:
1. Clean the MAF sensor element with a Q-tip soaked in brake cleaner. Be very gentle. 2. Remove the idle air control (IAC) valve from the throttle body and clean it (also with brake cleaner). 3. Remove EGR valve and give that a good clean as well. It's amazing how much effect the accumulation of 15 years' worth of crud can have on engine performance. Finally, run some seafoam through the brake booster vacuum line to clean out the engine's intake runners and combustion chambers. Don't be surprised if you see clouds of smoke come out of the exhaust. That's just the seafoam doing its job.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Mine was JUST doing the same thing. Throttle Position Sensor fixed me up right! Do you have a check engine light on? If so, see what the code is. If its 122. Then it's definitely a TPS.
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts. Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
IM having the same problem but when mine cuts off it doesnt cut back on...and sometimes when im driving ill be cruising at 2grand in RPM and my RPM will completely drop to zero then jump back up its like a real bad hesitation
Threads Similar to: 95 mustang gt dies out
| my mustang dies.... | RhadCundell | V6 Mustangs | 22 | November 30th, 2010 05:21 PM |
| Mustang dies/misses when hot. | 1NVERTED5.0 | 5.0 Mustangs | 50 | October 18th, 2010 11:43 PM |
| 88 mustang dies on hot days | trevorkb | 5.0 Mustangs | 0 | August 2nd, 2010 01:21 AM |
| Godfather of the Mustang dies | Lockup | The Clubhouse | 5 | March 30th, 2010 11:27 AM |
| 97 mustang gt dies for no reason. Help! | hamburgerpatty | 96-98 | 5 | August 27th, 2006 06:43 PM |
