1998 gt
advice on 347 kit badly!!!
my frd is selling his 347 kit to me for really cheap its used of course ($350) . but my problem is do i hav to hav mods to help support this kit. What do u think??
vortech v1 strim intercooled with lots of goodies , 4.10s, built rear end, pi intake, 78mm bbk tb, SCT tuner, bassani with flowmaster 44, mega bite jr lca, J@M full length subframe connectors, tuned by AED. and more suspension mods
1998 gt
should i buy it or save up for gears??
it will work by itself...it just will be held back considerably by the limitations of your stock top end. I would spend the money on something else if you dont already have HCI (heads, cam, intake) done...
350 for the kit plus whatever it will cost you to get your block machined, and the rotating assembly installed...Gears will be much cheaper.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
$350 is awfully cheap for a 347...
Is he selling a shortblock, or a rotating assembly? If its an assembly, with no block. It will require machine work to the block, new rings. new bearings. a bunch of measurements to be taken... then ofc you will have to notch the bottom of the cylinder bores so the rods dont interfere with the block plain and simple... unless this is a shortblock... you should probably skip it.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1998 gt
well he decided to sell me his motor that has the 347 kit on it. but its needs to be tuned and our manifolds swapped for it to work. Im worried i will get ripped off
1998 gt
do any of u guys hav any performance parts for sale btw???
1992 Mustang LX
13.0 @ 105
I'm pretty sure MK2 owns a shop...correct me if i am wrong.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
why does he want to get rid of it? How much for the shortblock? I would also find out who made the kit and who installed it/.
1998 gt
just 350 for the whole motor i raced him earlier and we were door to door??!!! i thought he would destroy me and apparently him and his dad installed it.
if he isnt pulling away from you like a mad man, with a 347... then something is seriously wrong with his car.
just another great reason to avoid buying it.
1998 gt
thats what i thought his excuse was it wasnt tuned
1992 Mustang LX
13.0 @ 105
BS a 347 should walk on a 302 pretty badly.
1998 gt
i didnt buy it he sold it to someone else the kit had a bad piston and rod i believe
1992 Mustang LX
13.0 @ 105
Hence why it was so cheap...If you see any kits for less than 500 be spectacle.
#15 | |
1998 gt
well he was a good frd and needed the money badly so was gonna sell it to me
Threads Similar to: advice on 347 kit badly!!!
| Just ordered the 347 kit.... | MOTOIMPAIRED | 5.0 Mustangs | 64 | July 31st, 2009 10:00 AM |
| 347 Parts Advice | losbucks24 | 5.0 Mustangs | 24 | December 31st, 2007 09:04 AM |
