gears
Old September 15th, 2010, 01:37 AM   #1
whiteout34's Avatar
1998 gt
whiteout34 is an unknown quantity at this point
gears
should i buy a limited slip differential or not when i get the 3.73 gears??? i heard mixed reviews about it. would it help me hook?? anything i should do when i put gears in???
vortech v1 strim intercooled with lots of goodies , 4.10s, built rear end, pi intake, 78mm bbk tb, SCT tuner, bassani with flowmaster 44, mega bite jr lca, J@M full length subframe connectors, tuned by AED. and more suspension mods
Old September 15th, 2010, 04:02 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Your rear axle should already have a limited sllip differential. Just buy a rebuild kit so you can replace the bearings and other parts that wear out with age.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old September 15th, 2010, 04:09 AM   #3
whiteout34's Avatar
1998 gt
people tell me i should buy the american muscle limited slip differential becz its better
Old September 15th, 2010, 04:10 AM   #4
whiteout34's Avatar
1998 gt
Old September 28th, 2010, 10:47 PM   #5
1995 GT 5.0
14.66
kpoirot is on a distinguished road
Send a message via AIM to kpoirot
If you're gonna spend money, get an Eaton Posi setup and that will be a true limited slip. If you don't want to spend much money then just rebuild your stock limited slip.
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts.
Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
Threads Similar to: gears
Speedo after gears. Where to buy gears and speedo fix... justinsstang V6 Mustangs 9 September 15th, 2010 02:57 PM
speedo gears for 4.30 gears bcinthearmy 94-95 2 April 23rd, 2009 12:02 AM
3.73 gears or 4.10 gears? I need to get away from the 3.31's 07torchgt 2005 - 2010 91 November 11th, 2007 12:25 AM
