Exhaust leak???
Old September 17th, 2010, 02:45 AM   #1
1991 mustang GT
14.12@99.89
91_FOX is on a distinguished road
Exhaust leak???
started car up last week and thought what i heard was a header gasket going bad. took it to my friends shop today and did a tune up set timing and had him make sure it was the header that was leaking before i took them off, and he says its the tube that runs from the back of the heads for egr? if i put my hand back there i can feel air. so whats the easyest way going about fixing this? he said i would have to take the heads off? im deff not trying to do that i was planning on doing that this spring and putting some AFR's on after i had the spair cash saved. Please help this sound just pisses me off everytime i drive the car sounds like a damn choo choo train lol
306, gt40x heads, msd ignition, gt40 intake, 75mm throttle body, 30lbs injectors, hooker shorties xpipe flowmaster 40 series,... SOLD.
Old September 17th, 2010, 09:57 AM   #2
95stroker's Avatar
1995 Mustang GT
95stroker is on a distinguished road
Why don't you just remove the smog system on the vehicle and plug the back of the heads with a bolt? The total bill will be under $40 with a shorter belt, plus you'll save a couple of pounds not having that worthless heavy smog pump on there...no need to take off the heads. Unless its the EGR line, but that runs from the EGR to the header, so again, the heads wouldn't need to come off.
Old September 17th, 2010, 04:18 PM   #3
1991 mustang GT
14.12@99.89
yea i was thinking same thing. i already have smog pump removed and shorter belt. i guess i would just remove the tub from headers and replace with a bolt? then for the tube going from head to head with some type of egr delete kit someone sells? but doing all this would the car throw a code? would it run any different?
Old September 20th, 2010, 12:29 PM   #4
408gt91's Avatar
408gt91 is on a distinguished road
Originally Posted by 95RED5.0
if you delete the smog pump make sure you plug the holes on the back of the heads
Originally Posted by AdderMk2
Which would require 5/8-11 bolts, no more than 1" long.
Make sure you get a battery terminal brush "bottle brush" and some carb cleaner, to clean out the threads in the back of the heads.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old September 22nd, 2010, 02:01 AM   #5
1991 mustang GT
14.12@99.89
thanks man, did it on sunday used a battery brush and it went in fine. it was still a pain in the ass but everything is fixed now
Old September 22nd, 2010, 08:20 AM   #6
408gt91's Avatar
Cool Brudda!
Threads Similar to: Exhaust leak???
Would an exhaust leak...??? BLK01SS 99-04 17 August 16th, 2009 05:24 AM
exhaust leak on 97 4v beheivjer 4V / SVT 10 August 26th, 2008 08:48 PM
Exhaust Leak? Gunny 2005 - 2010 8 December 3rd, 2007 11:35 AM
exhaust leak JASonic General Tech 7 October 14th, 2007 10:17 PM
exhaust leak? xedubx 99-04 9 July 19th, 2007 12:38 PM
