IAC valve or TPS?? almost crashed.....
Old September 20th, 2010, 11:22 AM   #1
justi88's Avatar
1994 5.0 Mustang GT
justi88 is on a distinguished road
Send a message via MSN to justi88
Exclamation
Well to start my 5.0 had issues with idle, every time I pressed the clutch the rpms would rise and come down after a few seconds and stay like at 1200 rpms. This problem was causing heating to my car and I donīt live in the U.S. so the only solution was adapting an IAC from a ford bronco.
So I picked it up from my mechanic and the idle wasnīt totally fixed but it was better, so last night i took for it a spin and gave it throttle until reaching like 80 mph when the throttle stayed open and I couldīnt stop the car so I pressed the clutch and the rpms when way up until the red line so i turned the car off and pulled to the side of the road. This scared the .... out of me and Iīm really pissed of with my mechanic.
So what i really want to know if this is caused by the IAC valve?? If it is I will buy the oem for my car. Please help me out to find out what is the problem...
Old September 20th, 2010, 11:26 AM   #2
1992 Lx
11.39@119.24
neither, your cable got stuck is my guess. The throttle stop is pretty close to hitting the bolts on the tb, cruise control cable coudla got stuck, it was something mechanical is my guess
Old September 20th, 2010, 12:07 PM   #3
408gt91's Avatar
408gt91 is on a distinguished road
Cable for sure. I bet the casing is dried out.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old September 20th, 2010, 02:38 PM   #4
justi88's Avatar
1994 5.0 Mustang GT
Are you guys sure that its the cable?? After the IAC was changed to the bronco type the idle was way up but no its a bit lower but it still hangs....
Maybe there is a way to check if its the IAC or tps???
Old September 20th, 2010, 03:23 PM   #5
408gt91's Avatar
Take off the iac and delete it, if it still hangs up i bet its the cable. Only time ive had idle jump that high was due to the cable. Either sticking or by me matting it. Its possible seing that its from a bronco. I used a 95 on a 93 once and it surged high but didnt stick and rev all the way up, that sounds more like the cable.
Old September 20th, 2010, 03:39 PM   #6
justi88's Avatar
1994 5.0 Mustang GT
ok 408gt91, by deleting the IAC what do you mean?? do i simply take it off and see if the idle still changes?? or by taking it off do i have to cover the port with something??
Old September 20th, 2010, 03:48 PM   #7
1992 Lx
11.39@119.24
just unplug it
Old September 20th, 2010, 06:55 PM   #8
408gt91's Avatar
^^^unplug. Its process of elimination.
Old September 20th, 2010, 06:59 PM   #9
fogged306's Avatar
89 GT
The IAC motor doesn't have enough of an opening to let enough air in to actually bring your engine to redline. The only way for that to happen is a stuck throttle. Like these guys have said, it's most likely a stuck cable. Replace it with one from a newer Toyota and you should be fine.
Old September 21st, 2010, 06:48 PM   #10
justi88's Avatar
1994 5.0 Mustang GT
ok guys thank youIīll check the cable and throttle body without IAC and let you know, just had a little problem with the fan last night and the car overheated... Iīll make a different post if I still have problems with heating...
Old September 24th, 2010, 04:44 AM   #11
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old September 25th, 2010, 01:01 PM   #12
justi88's Avatar
1994 5.0 Mustang GT
He is right, Iīll would change the cable from a toyota, most of the cars in my country are toyota so somethings just have to adapt... Anyway I found a shop that makes new cables so Iīll go with that
Old September 26th, 2010, 02:47 PM   #13
fogged306's Avatar
89 GT
lol, I was definitely just kidding about that. If you can, go with a stock replacement, that would be the easiest way to go. I would also check the pedal itself and disconnect the throttle cable from the throttle body and actuate the throttle body arm by hand and see if you feel any binding.
Old September 26th, 2010, 09:05 PM   #14
justi88's Avatar
1994 5.0 Mustang GT
its going to be very hard to find the stock replacement here, buying a stock one from the U.S. plus taxes plus shipping... its not worth it, iīll just find something here... also checked the pedal and its very loose and cable also so I think thats the problem... iīm thinking about buying the oem IAC from rockauto.com at 55$... donīt want that bronco IAC in my car
Old September 27th, 2010, 11:58 AM   #15
1995 GT
4Ever
Red95_5Oh is on a distinguished road
Send a message via AIM to Red95_5Oh
dude i work for fedex and i could send you a cable if you paypal me or something... i get massive discount on shipping. So you'll just have to pay the part and shipping cost. I can get a rough quote for you if you want. PM me.
Old September 28th, 2010, 10:36 PM   #16
1995 GT 5.0
14.66
kpoirot is on a distinguished road
Send a message via AIM to kpoirot
It could be sticky throttle body too and that would make the throttle stick open and if you changed the IAC could have made the change. Take some carb cleaner to the throttle body. Clean out the gunk.
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts.
Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
Old September 29th, 2010, 12:32 PM   #17
justi88's Avatar
1994 5.0 Mustang GT
what do you mean it could have made the change when i changed the iac??
Threads Similar to: IAC valve or TPS?? almost crashed.....
Problem with IAC? TPS? Need help!!! 98mustang 99-04 9 June 29th, 2010 04:31 AM
Iac & Tps dennislv 5.0 Mustangs 13 November 14th, 2009 11:11 PM
IAC/TPS ?? + cold running problems WildWill 94-95 13 November 6th, 2008 11:57 AM
IAC valve 89lx 5.0 Mustangs 1 April 22nd, 2008 03:30 AM
Throttle body, IAC, TPS, Mass air questions for my 347. problemCOBRA94 5.0 Mustangs 8 January 18th, 2008 05:33 PM
