94 budget mods...help
Old September 21st, 2010, 01:52 AM   #1
mustang416's Avatar
1994 Mustang Gt
mustang416 is on a distinguished road
Alright i have a 94 with minimal mods right now
headers, no cats, flowmaster mufflers, and a cai
i just got the car and its not as fast as i thought it would be. I also have a 96 3.8 liter which i think might even be faster.
I need help on what mods i can get to increase hp bad. And if there is a possibility to tune it so it runs better, i know most tuners are for the 96+ models only. Any advice would be appreciated
Old September 21st, 2010, 09:01 AM   #2
408gt91's Avatar
408gt91 is on a distinguished road
Heads, cam, intake, blower, nitrous, gears,etc. First thing i would do is gears and an aluminum flywheel.
408stroker/tf track heats/scat crank/h beams/srs fordged/351sportsman block/trick flow rrkrs/msd dist/edelbrock victor5.8intake/aeromotive fuel system/accufab 80mmtb/pro-m80mm,maf etc.
Old September 21st, 2010, 11:37 AM   #3
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
1. Clean the MAF sensor wire element.
2. Replace dizzy cap, rotor, plug wires, plugs, and fuel filter if not already done.
3. Upgrade fuel pump before adding more HP.
4. Remove unnecessary weight.
5. Gear swap: 3.55 for manual, 3.73 for automatic.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old September 21st, 2010, 05:09 PM   #4
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
[quote=Bullitt95;3169304]1. Clean the MAF sensor wire element.
quote]
+1
Make sure the cars running good before you start throwing money at it.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old September 21st, 2010, 06:54 PM   #5
mustang416's Avatar
1994 Mustang Gt
Right now it seems to idle and run a little rough, you guys both said to clean the MAF wires, would it be better to buy a new MAF?
Old September 21st, 2010, 07:26 PM   #6
mustang416's Avatar
1994 Mustang Gt
Oh and what would I need to do to turbo my car? I'd rather just find a cheap kit and try that out. Besides the bigger fuel pump/injectors what else would I really need? I can run about 8lbs of boost on stock internals right?
Old September 21st, 2010, 11:40 PM   #7
Siljin's Avatar
1995 Mustang GT
Siljin is on a distinguished road
A cheap turbo kit is a bad idea on the stock internals. The 5.0 engine was not designed to run much more then 300-350 horse and you would probably hit that at 6lbs of boost. Also finding a shop to tune the T4M0 ecu can be difficult. Of course you would have to tune the car with any major change that you make to the engine or it will run like a dog.
Conclusion: don't buy cheap chinese ebay turbo kits.
Old September 22nd, 2010, 08:23 AM   #8
408gt91's Avatar
[QUOTE=Conclusion: don't buy cheap chinese ebay turbo kits.[/QUOTE]
+1 lol!!
Old September 22nd, 2010, 12:16 PM   #9
mustang416's Avatar
1994 Mustang Gt
What would you guys do in my situation? I'm really into building this car but don't have much money and want to make this car somewhat fast. I know all the stuff to
make it styleish, but lack in the performance area
Old September 22nd, 2010, 04:03 PM   #10
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
5.0's can only handle 300-350 HP??? Damn, where have i been Your motor stock can handle about 450-500RWHP with a good tune. First i would do plugs,wires,cap,rotor,oil change,new filter and bump the timing to 16* Make sure you run 93 octane though. After that get some 3:73's if you have a stick and 4:10's for an automatic. Turbo kits are hard to install if you don't know mechanics....And paying for an installation is expensive.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old September 22nd, 2010, 04:04 PM   #11
1992 Mustang LX
13.0 @ 105
Also, how much do you have to spend?
Old September 23rd, 2010, 05:54 PM   #12
mustang416's Avatar
1994 Mustang Gt
I have about 800 to spend so not too much
Old September 23rd, 2010, 08:01 PM   #13
mustang416's Avatar
1994 Mustang Gt
How do you put the timing at 16?
Old September 23rd, 2010, 10:48 PM   #14
1992 Mustang LX
13.0 @ 105
If you're asking how, just take it to a local shop and ask them to do it for you. You need a timing light to shoot the car.
Old September 24th, 2010, 04:52 AM   #15
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
Mine was slow as shit until I did a tune up...turned out I had the original Ford fuel filter on it.
She's in the shop right now, getting an IRS and 4.10 gears put in, I'm hoping to get it back tomorrow or saturday, I'll be sure to come on and let everyone know how I like them.
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old September 24th, 2010, 08:17 AM   #16
bradtheblade's Avatar
1995 cobra
slow show car
bradtheblade is on a distinguished road
no fair i want irs. as for cheap mods eliminate the ac and smog/air pump less drag=more power with only 800 bucks for mods your best bang for your buck would be a wet shot.that said there are other mods you could do but for the most hp gain for the money the no2 is my opinion.
Old September 24th, 2010, 08:23 AM   #17
Bullitt95's Avatar
13.546 @ 105.32
That's a lot more than I have right now. In that case do:
1. Free Modifications
To those you can also add AC delete, underdrive crank pulley, and shorter belt.
2. Weight Reduction
3. The first 3 items I mentioned earlier.
You'll notice a significant difference and it'll cost you very little money. You can do the gear swap after you've saved up a bit more.
243.5rwhp/284.2rwtq
Old September 24th, 2010, 03:08 PM   #18
mustang416's Avatar
1994 Mustang Gt
Thanks guys this really helped a lot
Old September 28th, 2010, 10:39 PM   #19
1995 GT 5.0
14.66
kpoirot is on a distinguished road
Send a message via AIM to kpoirot
New plugs, wires, cap, rotor, and coil could do ya some good too if the car is running rough.
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts.
Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
Threads Similar to: 94 budget mods...help
I have a budget of $10,000 -- Let the mods begin!!! Tmac3320 99-04 71 January 8th, 2010 06:40 PM
New 04 - Budget mods, suggestions appreciated Morpheus V6 Mustangs 8 April 27th, 2009 04:49 PM
What mods do you recommend for a new mustang with my budget? silvel2edge 2005 - 2010 11 April 29th, 2007 01:50 PM
Performance Mods on a budget RoushRacing99 99-04 20 January 21st, 2007 04:59 PM
Mid Budget Mods left_hand_of_heaven V6 Mustangs 7 November 9th, 2006 06:49 PM
