1995 Mustang GT
Rear axle seal question
I have a slight leak out the end of my driver side rear axle. I purchase a set of seals and barings, but my question is, how difficult are these to install and does anyone know where I can find a step-by-step description? I have a pretty good idea from my chilton's manual, but I'd like more specific details. Thanks for your help in advance!
![]() Aluminum heads, TF upper/lower, bbk tb c&l intake w/Pro*M Racing MAF, shorty headers 24# injectors, off-road H, custom catback H&R springs, 3.73's short throw.....still slow. |
94 mustang gt
too slow to tell
you need to remove the diff cover take apart the posi unit so that you can get to the c clip inside to remove the axle then you will need a bearing puller in order to get the bearing out and then you should get a race/seal installer so that you dont damage the bearing or seal while installing
Threads Similar to: Rear axle seal question
| Rear axle question | sharkbait | 99-04 | 1 | May 4th, 2010 10:40 AM |
| Rear Axle Question | 84MustangGT | 5.0 Mustangs | 7 | August 31st, 2009 09:11 PM |
| Question on Replacing Rear Main Seal | The Novice | 5.0 Mustangs | 5 | June 27th, 2009 05:38 PM |
| leaking axle seal question | TwitcH_SN95 | 94-95 | 3 | March 14th, 2009 10:09 PM |
| rear transmission seal???? | snakey5138999 | V6 Mustangs | 5 | February 8th, 2008 02:43 PM |
