just bought this car.... need some advice on upgrades
Old September 26th, 2010, 09:31 PM   #1
1995 mustang gt convertib
leeowens is on a distinguished road
i just bought a 95 gt vert and i was told these things have been done to it and i was wondering what should be my next move performance wise????
In the past year it has had a new water pump, new radiator, msd plugs wires distributor cap and rotor button, accel performance module, ford racing performance clutch, pro 5.0 short throw shifter, bbk cold air intake, egr and smog pump delete. new drive belt and tensioner. As far as performance upgrades... it has pypes shorty headers and a full 2 3/4 inch pypes exhaust with x pipe and straight through muffler . the bbk intake . Suspension it has is eibach pro kit lowering springs tokico d1 spec fully adjustable shocks motorsports adjustable caster and camber plates on the front. also has brand new front and rear brake pads and rotors, along with new U-Joints in the drive shaft..... any advice is very much appreciated
Old September 27th, 2010, 03:58 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Two things you can do to get the most bang for your buck:
1. A 3.73 rear gear swap.
2. Remove unnecessary weight, beginning with the 25lb weight that's bolted to the passenger side inner fender under the plastic liner. For other ideas go to Weight Reduction
243.5rwhp/284.2rwtq
Mod list in My Garage
Old September 27th, 2010, 09:52 PM   #3
So 373 is a good gear if i drive it on the highway and around town? its my everyday driver and ive never had gear in none of my cars. thanks
Old September 28th, 2010, 12:13 AM   #4
Siljin's Avatar
1995 Mustang GT
Siljin is on a distinguished road
Currently run a T5 with 3.55 gears in the back and I would not recommend using anything above this for a daily driver. I am considering going to a more streetable 3.27 ratio even at 3.55 simply so I don't have to shift as much.
Also Bullit95, do you have any photo's of the weight that your referring to?
Old September 28th, 2010, 03:29 AM   #5
Bullitt95's Avatar
13.546 @ 105.32
No, but if you pull off the plastic fender liner on the passenger side it'll be right there in front of you so you can't miss it. When you do the rear gear swap you can also remove the 8lb "dogbone" that's bolted under the differential.
On a coupe I'd agree with you but on the heavier vert, the 3.73 would be a better option.
Old September 28th, 2010, 02:40 PM   #6
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Whatt?? I have 3.73's and they are perfect for around town driving. Not wanting to shift a lot is just being lazy I still say 3.73's are the best all around gear!
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old September 28th, 2010, 10:30 PM   #7
1995 GT 5.0
14.66
kpoirot is on a distinguished road
Send a message via AIM to kpoirot
3.73 Gears would be the way to go. I have 'em in my car and it's amazing! Maybe a Trickflow upper and lower intake would be the next step?
Mods:Underdrive Pulleys, Ram Air w/ K&N Filter, Rebuilt T-5, 3.73s, High Flow H-Pipe, Energy Suspension Poly Motor and Tranny Mounts.
Soon: Un= headers, Centerforce Clutch, Steeda Tri-Ax Fidanza Alumnum FW, BBK 75mm TB, EGR Elim.
Threads Similar to: just bought this car.... need some advice on upgrades
Need Help! Bought first car need advice! firstcarpony Classic Mustangs 45 March 18th, 2010 07:43 PM
need advice for 3.8 performance upgrades Rebel102469 V6 Mustangs 20 August 19th, 2007 11:39 AM
need advice on upgrades for supercharger fastlane_24 94-95 7 July 10th, 2007 12:06 PM
i am going to buy these upgrades need advice fastlane_24 94-95 2 May 30th, 2007 12:28 PM
need advice on upgrades fastlane_24 94-95 3 January 15th, 2007 12:32 PM
