Tranny and Check engine light issues.... interesting problems, help appreciated!
Old September 29th, 2010, 12:06 PM   #1
1995 Mustang GT
deeppurple95 is on a distinguished road
Send a message via AIM to deeppurple95
ok so... two different problems here.
1.) I have been getting a check engine light on my car, finally pulled the code and it says that the heated O2 sensor indicates my left bank is running lean, what could this be caused by? bad sensor? something on the other side of the cylinder? (ie MAF, intake, plugs, injectors,etc?) The cats have been punched out of the exhaust, but it IS a stock midpipe. Should i get a retune to correct this problem? no cats means less backpressure, means gas flows faster past those sensors, means different reading, am i right?
2.) when i am shifting, as i engage each gear, i can feel the synchros/gears engaging. This doesnt seem healthy (all stock drivetrain, no mods) for the tranny, and it is disconcerting while driving. The clutch has been slipping if i try to give it too much gas at highway speeds, such as when i downshift into 4th to do an easy pass, the RPMs spike and i have to feather the throttle. this to me points to a worn clutch. another weird thing is, only the top 1/4 of my clutch pedal's throw is actually used to engage/disengage the clutch, from the feel of it, so could this mean a maladjusted cable?
Threads Similar to: Tranny and Check engine light issues.... interesting problems, help appreciated!
Check engine light 06HellFireGT 2005 - 2010 18 June 26th, 2010 08:41 PM
check engine light came on.... tomasmk2003 4V / SVT 34 March 11th, 2010 08:23 PM
Transmission issues? Any help greatly appreciated Bobert 99-04 20 February 23rd, 2010 03:24 PM
Check Engine issues... Regulator 99-04 6 April 27th, 2009 07:47 PM
Potential problems/issues with engine swap robz301 V6 Mustangs 22 December 26th, 2007 02:19 AM
