94 Mustang GT
intake removal
i have a trick flow upper and lower intake. i want to remove the upper intake so i can put in a 1" spacer in between the two. are there any special tools or any thing special i need to do. if not how do you remove it?
1992 Mustang LX
13.0 @ 105
All you need is normal hand tools. Just unbolt it and then get a new gasket when you put it back on.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
95 opalfrost gt
Whay would you want to put a spacer under that intake. Unless you have valve cover interference there isnt a need to do so.
94 Mustang GT
yes i am having valve cover clearance and having a hard time removing the rear bolts on the upper intake.
1993 Mustang GT
They are pain in my assholes... Sorry.
But with those, at least on my 93, it just took time and patience. One turn by one turn. Get an extension and try that. I remember for some that I needed an extension, and with others it wouldn't fit. The harder part is when you put the TF intake on.
I have a 93 5.0 I love my car, and all my friends hate it. ![]() AEM Brute Force intake, BBK 75mm TB/EGR, C&L 75mm MAF, Trick Flow Street Upper/Lower, Custom exhaust with Dynomax SuperTurbos, Tokico Rear Shocks |
95 opalfrost gt
You have me lost .... you said it is already on the car and then you are saying your having valve cover interference. How is this possible if it is already on the car what is the problem I dont get it. Can you elaborate on what the problem is.
94 Mustang GT
yea, the person that put it in shaved the iac and the egr and it now they rubb on the valve cover and stalls at stops.
Threads Similar to: intake removal
| removal of intake manifold. | flattusmaximus78 | 5.0 Mustangs | 20 | May 18th, 2010 04:54 AM |
| intake removal | Wiley | V6 Mustangs | 22 | December 18th, 2008 04:00 PM |
| 97 Cobra intake removal question | dilireus | 96-98 | 1 | January 7th, 2008 11:14 AM |
| ported lower intake with IMRC removal | 02ponypackage | V6 Mustangs | 29 | August 31st, 2007 09:57 PM |
| intake removal | dumps | 2005 - 2010 | 1 | May 17th, 2007 11:53 PM |
