'94 GT Coupe
Slim fan wiring
I think I've asked this question before but never got a clear answer.
I have an aftermarket slim fan and need to know how to wire it up. I had it on a toggle switch but went horribly wrong.. The stock fan harness has a lo power, hi power, and ground wire. This fan has a power and ground. The wires on the fan was much smaller than the harness but I was wondering if I could splice the low and high powers together and the ground opposite. |
#2 | |
95 opalfrost gt
'94 GT Coupe
I wired a manual switch previous and the wire from the battery to the switch ran fire hot and then melted the wires and caught on fire.
95 opalfrost gt
Cause you did it wrong! Grab 12v power from inside the car thats hot on ignition. This way when you turn rhe car off the fan wont stay running and kill your battery. When you wire it in use 1 gauge thicker wire than what your tapping into. Also use an inline fuse along with a good ground and you shouldnt have a problem. You can also pin into the low speed pins on th ccrm.
Threads Similar to: Slim fan wiring
| Slim fan for procharger or any supercharger | TotoGT06 | 2005 - 2010 | 1 | September 22nd, 2010 03:52 PM |
| Electric Fan Wiring | 89stang5.0 | 5.0 Mustangs | 21 | June 7th, 2010 10:17 AM |
| Electric fan wiring??? | shurb125 | 5.0 Mustangs | 15 | March 5th, 2008 11:38 PM |
| Electric fan wiring | 8A_Honda | 5.0 Mustangs | 18 | June 22nd, 2007 04:44 AM |
| electric fan wiring | 91foxhatch5.0 | 5.0 Mustangs | 1 | May 15th, 2007 08:29 AM |
