1995 Mustang Gt
Ignition help...
How difficult is it to do an ignition switch on the on the cylinder/key switch??? Anyone have any idea?
if you look at the bottom of the column, you will see a small hole. Turn the ignition to the RUN position, and insert a long thin phillips head screwdriver into the hole. This will release the ignition lock from the column.
Once you have the tumbler out, you can unscrew the column cover and access the switch assembly. It should be pretty self explanatory from there on out.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1995 Mustang Gt
All right so this doesn't involve pulling the whole steering column out at all then? I don't need a steering wheel puller or any of that? And what kind of ignition would you go with since I'm going to be replacing it just anything from autozone or something better?
a GP Sorensen(Advance Auto) piece will suffice. Its not a part that is typical, or prone to failure.
just buy one with a warranty... if a few extra bucks now, can save you more down the line... its a worthy investment.
1995 Mustang Gt
Threads Similar to: Ignition help...
| Zero Ignition, what to do? | MyGT | 5.0 Mustangs | 12 | January 13th, 2010 10:25 AM |
| need help with ignition | samuel642000 | 5.0 Mustangs | 0 | February 12th, 2009 11:04 AM |
| MSD Ignition Or Crane Ignition | jg347stroker | 5.0 Mustangs | 0 | December 2nd, 2007 10:05 PM |
| Ignition | terribleonexx88 | 5.0 Mustangs | 6 | November 23rd, 2007 09:59 AM |
| Ignition | maverick | 2005 - 2010 | 30 | January 12th, 2007 07:11 PM |
