Weight reduction
Old October 4th, 2010, 11:52 PM   #1
jordon's Avatar
1995 Mustang GT
jordon will become famous soon enough
Weight reduction
Now that I have a great majority of the performance upgrades that I would like done....at least until after winter.....I'm starting to think about weight reduction. I've noticed now after my lowering spring install that my passanger side is about 1/4" lower than the driver side and I would assume that it is due to bad weight distribution. Any ideas as far as evening that out?
Any other suggestions as to other sources of dead-weight, besides the obvious spare tire removal and rear seat delete would be appreciated. Thanks!
Aluminum heads, TF upper/lower, bbk tb
c&l intake w/Pro*M Racing MAF, shorty headers
24# injectors, off-road H, custom catback
H&R springs, 3.73's
short throw.....still slow.
Old October 5th, 2010, 08:13 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Look no further than my Weight Reduction list.
If you have a vert, you can also remove the 25lb weight that's bolted onto the inner fender under the liner.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old October 5th, 2010, 08:55 AM   #3
1997 mustang gt
jhills2 is on a distinguished road
that is not due to weight distribution...that's due to the classic mustang ghetto lean, ford engineers have admitted to this issue. no biggie
Eaton SC 6psi, 4.10 gears, PI cams, CAI, 70TB, OR-H, Bilstien struts/shocks, B springs, MM C/C, B&M trans cooler, 10th anny cobra brakes
Old October 5th, 2010, 10:54 AM   #4
jordon's Avatar
1995 Mustang GT
HAHA...ghetto lean, I like it. Thanks tho. I was a bit worried I did something wrong with the install.
H&R springs, 3.73's
Old November 30th, 2010, 11:58 AM   #5
Lil302's Avatar
1995 Mustang Gt
Lil302 is on a distinguished road
I'm curious as to why exactly there's that ghetto lean though
Old November 30th, 2010, 03:45 PM   #6
95project is on a distinguished road
fixing the ghetto lean is simple...only look at the car from the side that you think looks better
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old November 30th, 2010, 04:46 PM   #7
Ginger with No Soul
NASTY03GT's Avatar
2003 GT, 1995 GT vert
13.043@108.46
NASTY03GT will become famous soon enoughNASTY03GT will become famous soon enough
In all seriousness, another option is racing seats like Corbeaus. They are much lighter than stock seats.
http://www.youtube.com/watch?v=SLkmi9igM8g
^^^Let a Chic show you how to do a burnout!!^^^
Originally Posted by 01stangV6 View Post
Damn Canadians.....always saying "eh".....pisses me off.
Black Stang Crew
Member #HOT STUFF
Old November 30th, 2010, 05:06 PM   #8
upgrading suspension parts will also free up some weight. Most all aftermarket parts are stronger and lighter than the OEM..atleast they balance out the additional weight of sub frame connectors..which are a must!
Aluminum driveshaft will help a good bit
Removing the smog pump
Factory crap amps and rear dash speaker box
move your battery to the trunk for better weight distribution..
Old December 6th, 2010, 09:11 PM   #9
Lil302's Avatar
1995 Mustang Gt
is there any real reason as to why the car leans that way. I actually looked at my car and i couldn't believe it actually leans on the passenger side. But i can't understand why it would have been designed that way.
Old December 7th, 2010, 12:18 AM   #10
Bullitt95's Avatar
13.546 @ 105.32
Maybe it was so that it would be balanced when the driver sits in it.
Old December 8th, 2010, 09:26 PM   #11
roast&toastEM's Avatar
1994 Mustang GT
roast&toastEM is on a distinguished road
i wonder what weight ford recommends for their driver then so it evens out?...
1994 Mustang 5.0
Old December 12th, 2010, 05:37 PM   #12
Lil302's Avatar
1995 Mustang Gt
That's a very good possibility.
Old December 13th, 2010, 12:50 AM   #13
s351r13's Avatar
1996 Saleen S351
s351r13 is on a distinguished road
You have to set the springs up correctly. Make sure if you retain the isolators you do the same with all the others. You also need to have them clocked exactly the same.
96 S351 #13
99 S351 #14
99 S351 #46
94 S351 #35
95 S351 #43
00 S281 #417
02 S281SC #117
Old December 13th, 2010, 12:13 PM   #14
jordon's Avatar
1995 Mustang GT
Believe me, we were very cautious, taking note of everything from how the springs sat in their places to how tight bolts were....everything. I didn't want to mess with alignment or anything if I did not need to. Everything turned out great and alignment was damn near right on....except for the slight "ghetto lean." We will find out how everything settled over the winter when I get her out this spring.
H&R springs, 3.73's
Threads Similar to: Weight reduction
weight reduction!!! StangBanger302 5.0 Mustangs 18 July 5th, 2010 11:56 PM
What else; weight reduction! McMustang5.0 5.0 Mustangs 30 February 18th, 2010 07:47 PM
weight reduction? takiller 99-04 30 January 30th, 2008 04:54 PM
How Is This For Weight Reduction 1bad281 Multimedia 4 January 28th, 2008 12:13 AM
weight reduction oh2swapped 99-04 2 December 31st, 2007 02:11 AM
