No Brake Lights/ No Cruise Control!
LinkBack (1) Thread Tools
Old October 7th, 2010, 04:48 PM   1 links from elsewhere to this Post. Click to view. #1
1994 Mustang GT
WhiteLies is on a distinguished road
Send a message via AIM to WhiteLies
Brake Light Switch NOT Engaging
A while back I replace the brake light switch and the light bulbs. Now I realize that I have no brake lights again, coincidentally no cruise control which I haven't used in probably 3 years. Need suggestions! I have checked fuses, they seem fine. Checked to see if there were any wires loose, nope! I am at a loss!
It seems the switch is working on its own but only when you click it alone, it will not engage when you push on the brake.
Old October 11th, 2010, 10:11 PM   #2
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
check to see that the sensor in the brake pedal is still connected. If the cruise control AND brake lights both dont work its definitely a physical problem within the pedal. check to see that everything is connected.
.............................2000 GT Vert.............................
How To Cut/Remove springs
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/186815-no-brake-lights-no-cruise-control.html
Thread No Brake Lights/ No Cruise Control! | Forums at Modded Mustangs | BoardReader This thread Refback June 21st, 2011 02:08 AM
Threads Similar to: No Brake Lights/ No Cruise Control!
cruise control help matt.matejcek 96-98 3 March 1st, 2009 08:56 PM
Cruise Control zinc02GT 99-04 1 December 31st, 2008 08:20 AM
cruise control HBK_2007 96-98 3 May 25th, 2008 01:56 PM
help: cruise control orlyr21 General Tech 1 June 12th, 2007 12:42 PM
cruise control... 97mustangchik25 V6 Mustangs 5 July 24th, 2006 10:26 AM
