Wide Band Install
Old October 8th, 2010, 11:00 AM   #1
95project is on a distinguished road
Wide Band Install
I'm going to be installing my AEM Wide band today.
Anyone heard of wiring this in with the EGR as well? What will it do and how do i do it?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old October 8th, 2010, 12:13 PM   #2
Trick Tuners's Avatar
KB'd GT
No. Why would you do that?
Old October 8th, 2010, 12:56 PM   #3
I have heard that wiring your wideband in through the EGR plug will allow for for easy datalogging.
Old October 8th, 2010, 01:15 PM   #4
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I have NEVER heard of that...
Facebook
Google+
Old October 8th, 2010, 01:50 PM   #5
Ok. Normal install it is.
Old October 8th, 2010, 03:08 PM   #6
Any suggestion on where to put the o2 sensor. I have BBk LT's, BBK X Pipe...no cats...
there is an available bung on the bottom of the LT's just before the connection to the X pipe...and also one in the mid pipe...
is it ok to put it in the header itself?
and best side is drivers right?
Old October 9th, 2010, 11:39 AM   #7
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
Any of you who have never heard of running the wideband through the EGR for easy datalogging, must be spoiled with dyno's and external AFR monitoring.
For those of us who tune on our own, with equipment like the Moates Quarterhorse... have to find ways to get the AFR data in line with the rest of our log data.
The way this is done, is by setting the EGR to disabled, in the tune. You then connect your 0-5v analog output from the WBO2 to the EVP SIG wire, which reporta EGR valve position to the ECM.
You then go into Binary Editor, and set a new transfer function for the EVP, and have binary editor report it into your datalog as AFR. You can then change the points on your digital dashboard to show the reported data, which then falls in line with your other recorded data, and allows for easy readback and data processing.
95project, I apologize that I havent gotten back to you on this, I will send you more complete information when I have a chance. I am currently in Wisconsin, training up for a tour overseas. My net connection is crap, and my time is limited.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old October 9th, 2010, 04:43 PM   #8
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I run a innovate LC-1 with XD-16...Datalogs just fine for me with my wideband sensor...And I dont tune my car...My car is tuned by GREAD Tuning in Louisville Kentucky...
Facebook
Google+
Old October 10th, 2010, 02:59 PM   #9
thanks man. i appreciate it. i will be ordering the QH tomorrow. not my DD so no huge rush...i appreciate your help and appreciate your service to this country even more. PM when you get a chance.
Threads Similar to: Wide Band Install
Wide Band recommendations 95project 5.0 Mustangs 4 September 10th, 2010 12:40 PM
where to put a wide band? Ideas. 0949er 99-04 22 July 13th, 2010 01:06 PM
Wide Band Bung Location DavidsV8Mustang 99-04 26 May 13th, 2010 04:49 PM
Where does the sensor for the wide band go?? pqtiii 2005 - 2010 1 April 30th, 2010 09:24 PM
Wide Band ryans88gt 5.0 Mustangs 13 January 10th, 2008 09:10 PM
