Crank Sensor?!?! - Forums at Modded Mustangs
post #1 of 16 Old October 11th, 2010, 11:42 PM Thread Starter
Crank Sensor?!?!
does anyone kno where the crank sensor is located in the motor and wats the signs of a bad crank sensor?? THANKS id really appreciate any feedback and advice
1995 5.0
MODS: wide mouth headers straight pipes flomaster exhaust.
RED BONE V6 is offline
post #2 of 16 Old October 12th, 2010, 08:27 AM
Send a message via AIM to AdderMk2
doesnt have one
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
AdderMk2 is offline
post #3 of 16 Old October 12th, 2010, 10:25 AM
Resident Headbanger
Bullitt95's Avatar
The 5.0 doesn't have a separate crank position sensor but it does have a Hall Effect PIP sensor inside the distributor that acts both as a crank sensor and as a cam position sensor. When this component begins to fail, the engine will randomly stall (tach falls to zero) without spluttering and restart after a few seconds or minutes. As the problem gets worse, the stalling becomes more frequent and the engine ultimately becomes difficult or impossible to start. Failure of the TFI module can produce identical symptoms but usually its demise is more rapid.
2006 GT - 5MT - 310rwhp 328rwtq - 12.67 @ 108.61 - Mod List
Sold: 1995 GT Green, 1995 GT Red
Bullitt95 is offline
post #4 of 16 Old October 12th, 2010, 03:47 PM Thread Starter
i changed both and still doing exactly wat u described
1995 5.0
post #5 of 16 Old October 13th, 2010, 02:34 AM
Resident Headbanger
Bullitt95's Avatar
What parts did you use as replacements? The reason I ask is that it won't be the first time that a "new" part has turned out to be a dud.
post #6 of 16 Old October 13th, 2010, 02:00 PM Thread Starter
i gotta brand new distributor from auto zone duralast...and a NAPA TFI module bcuz i couldnt find them at auto or Advanced Auto
1995 5.0
post #7 of 16 Old October 13th, 2010, 06:15 PM
Resident Headbanger
Bullitt95's Avatar
That could be the problem. I suggest you either try a brand new genuine Ford unit or borrow a used distributor from a friend that's known to be good.
post #8 of 16 Old October 21st, 2010, 12:54 AM Thread Starter
could it be my 02 sensors...my computer is also tripping these codes 116 172 136
1995 5.0
post #9 of 16 Old October 21st, 2010, 02:05 AM
Resident Headbanger
Bullitt95's Avatar
Bad O2 sensors will only cause poor fuel consumption, not a no start or stalling problem.
post #10 of 16 Old October 22nd, 2010, 12:08 AM Thread Starter
fuel injection maybe....the codes say my system in running lean
1995 5.0
post #11 of 16 Old October 22nd, 2010, 09:04 AM
dont just start throwing parts at the car... A lean condition is often caused by a decent sized vacuum leak, which our cars are notorious for
[SIGPIC][/SIGPIC]
AdderMk2 is offline
post #12 of 16 Old October 22nd, 2010, 04:05 PM Thread Starter
How can I Check for vacuum leaks
1995 5.0
post #13 of 16 Old April 28th, 2013, 05:09 PM
they usally break under the intake manifold, that's were mine were, rite where u cant see them. see if u still have 2 vacuum line coming from under the intake man torward the fire wall that's were I found mine vacuum leaks
grilla is offline
post #14 of 16 Old July 24th, 2013, 08:22 PM
5oh1990's Avatar
Does this also apply to the 83-93 5.0 foxes? I tried looking up crank position sensor by car/model (1990 mustang) and came up with no results however when i looked it up via engine (302) it came back with a part number.. it did however use a 96 Bronco as the intended car.. anybody know something i dont??
I'm new to MODs so plz excuse the stupidity.
5oh1990 is offline
post #15 of 16 Old July 25th, 2013, 09:30 AM
Resident Headbanger
Bullitt95's Avatar
It certainly applies to 86-93 Foxes. I don't know if it still applies to non-roller block 5.0's though.
post #16 of 16 Old July 25th, 2013, 03:42 PM
5oh1990's Avatar
thanks Bullitt95. Looks like ill be returning the CPS i got from Autozone and instead purchasing a new distributor, no point in spending $30 if i didnt need to.
5oh1990 is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/187441-crank-sensor.html
Crank sensor - forum posts | BoardReader This thread Refback October 12th, 2010 11:13 PM
