header clearance?
i just put my equal length bbk ceramic shortys on and my steering shaft was rubbing on them. has anyone else had this problem if so what did you do ? i used a grinder and got it clear but what else can be done ?
95' GT is being reconstructed! |
I had the same problem, they fit fine with my stock heads but when I went with tfs on my stroker then they rubbed. what I did was dent the header just enough for it to clear. It sucks taking a hammer to something like that but it will fix it. I didnt see any difference on the dyno as far as horsepower from denting it so dont worry.
well i have clearence now after i ground down the shaft but i was wondering if they made a different steering shaft or relocater plus my headers are ceramic coated i wasnt even going to try and dent them. but thanks anyway
Maximum Motorsports makes a steering shaft for around $100.00 I believe it is skinnier but stronger. the website is: www.maximummotorsports.com
Threads Similar to: header clearance?
| header ground clearance issues | dshep | 99-04 | 11 | September 24th, 2007 06:38 PM |
| header clearance | 408gt91 | General Tech | 1 | August 23rd, 2007 09:52 AM |
| LT header clearance | blk98gt | 96-98 | 4 | June 27th, 2007 06:17 PM |
| Springs and Header Clearance | UTGT | 99-04 | 5 | June 7th, 2007 04:13 PM |
| header clearance | My67_fastback | Classic Mustangs | 6 | February 25th, 2007 04:03 PM |
