1995 Mustang GT
94-95 Alternator Bracket
Anybody found one for the 94-95's? I contacted march, and theirs will not work due to the 94-95 Mustangs' water pump. I see Moroso and Canton have setups that look like they may work, but after some searching I haven't really found much of anything for people saying working for sure. I'm not running smog or a/c, and wouldn't mind a different power steering bracket either, but lets start with the alternator....thanks for your help.
nobody makes one.
most people (myself included) cut the smog half of the bracket right off
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1995 Mustang GT
You're positive? Thats insane if they don't make one that fits...not any of these work?:
Ford Mustang Spectre Performance Alternator Bracket - 4723 Canton Racing Products 75-224 - Canton Racing Alternator Brackets - Overview - SummitRacing.com Moroso 63810 - Moroso Alternator Brackets - Application - SummitRacing.com Roush Performance R21020005 - Roush Alternator Brackets - Overview - SummitRacing.com |
go ahead and order one.... just dont cry like a baby when you figure out i wasnt kidding
1995 Mustang GT
Uh, I believe you. I was simply asking.
#6 | |
Dig out the angle grinder and get to work.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1995 Mustang GT
Actually, I went on your website last night and marked my bracket off of your pictures! A little grinding and powdercoating should clean it up pretty nicely.
Yeah, the whole bracket including the smog pump part only weighs ~4lb so if you cut that off, the remaining bracket is only ~2lb. The alternator is a hefty 16lb mofo so you definitely need a beefy bracket to hold it in place. Some of the cheap aftermarket brackets look pretty flimsy to me.
1994 mustang gt
10.82 sec
i only run an alternator,i have no power steering,electric water pump,no ac,and no smog,i made my own bracket and used a turnbuckel for the adjuster,i have like 6 bucks into it
seans mustang
95 mustang gt
get a foxbody timing chain and water pump....blam...alt bracket will work then
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
Threads Similar to: 94-95 Alternator Bracket
| Is This An Alternator Bracket And Where Does It Go? | Gregski | Mustang II | 8 | December 21st, 2010 10:33 PM |
| Custom alternator bracket | MikeyS281 | 99-04 | 4 | May 16th, 2010 05:42 PM |
| alternator bracket!!!! | show95stang | 5.0 Mustangs | 4 | June 1st, 2008 01:51 PM |
| alternator bracket | 91cobra5.0 | 5.0 Mustangs | 0 | May 29th, 2008 06:55 PM |
| Alternator Bracket | acg | 96-98 | 2 | October 6th, 2006 08:38 PM |
