1994 Mustang GT
94 Mustang GT im new and was looking for help on building my car
I have a 1994 Mustang GT 5.0l high output and i was hoping someone on here could point me in the right direction as to what i could do to increase the horsepower and torque of my car like i said im new and am just looking for friendly advice!!!
Thanks to all who help!! Caleb
Burn the road up!!! |
Is you car manual or automatic? Either way, the best starter mod is a 3.73 rear axle gear swap. It'll feel like you've added an extra 80hp right off the bat.
You could visit my homepage and find out what freebie and weight reduction mods are possible on our Stangs.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1994 Mustang GT
![]() iTrader: 2 reviews
^+1
ur page is great for any beginner to see and learn a few things from.
![]() 1994 Mustang 5.0 |
1994 Mustang GT
i was planning on getting the 3.73 gears for it it has 3.08 right now and its a manual oh yes and 3rd gear feels week in my car is that a normal thing for that yea cause ive checked it out and it dosent seam to have any problems and what could i do to help it
If you don't know the car's service history, you'd be well advised to do the following:
1. Replace plugs, plug wires, distributor cap, rotor, and fuel filter. 2. Clean the MAF sensor. 3. Clean the EGR valve. |
1994 Mustang GT
my father is a mechanic so we tak great care of it service wize and all
Looks like you got yourself a project in the making. A shifter was one of the first things that I did with my car. The stock one is a POS, very rubbery feel to it. Exhaust is always nice to get the sound your looking for while you save up for the more expensive mods.
1995 Mustang GTS 46K Miles with some bolt-ons. http://www.youtube.com/irishcarbombs85 |
95 opalfrost gt
Gears, exhaust, under drive pulleys, advance timing. Those four things are a good start and great foundation to build on.
95 Mustang GT
1st mod, subframe connectors /thread
![]() People should think about boarding up their glass house before starting a rock fight! |
If it was a Fox or an SN95 vert, I'd agree with you but they're not necessary at such an early stage on an SN95 coupe.
Last of the 302's
Road Racing Rookie
A great and cheap way to get more power is get yourself a set of gt-40 iron heads from someone. $400 is the average going rate for them. Get them freshened up with new seals and springs if not already done and slap them on. The only modification needed to make them work is getting the rite head bolts for them. Since they are a 351 based heads they have larger holes for larger bolts. You can go about this 2 ways. Either get step washers, which is the way I went, or get the bolts designed for this swap. They'll have a large body to fill in the bigger hole but the same smaller size thread to bolt into the block. Step washers is the cheaper way to go.
While your at it or even later down the road you can get yourself a new intake (upper/lower). You can find one specifically for the 94-95 or you can use an intake designed for the 93 older cars. When using the older intakes you'll need to also get an elbow adapter because the 94-95's have a 45 degree type turn on the front of the upper intake and the 93 older don't. By using an adapter on the older intakes the throttle body ends up in the same place allowing you to reconnect everything back the same way.
![]() Victor ( goofyfeet) Oliver P.B.M.C. Member Track Addict |
biggest bang for your buck at this stage will be rear end gear, bump up timing, exhaust and a cold air intake...
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1994 Mustang GT
thank you guys for all the advice so far this is what came on the car when i got it from its origional owner
full racing suspension full exhaust and headers new cam and crank im getting gt-40 heads for it soon also(hotmustang95) like i said thanks to all of you for the info i am really glad there is still nice people in this world
1994 GT
u should elaborate on "full racing suspension"
Cohagan Engineering, Inc. |
95 Mustang GT
+1 is that what the guy that sold it to you said? A lot of people like to make things sound like more than they are, like he put a set of shocks on from NAPA and now when he sells it he says full racing suspension cause the box the shocks came in said "racing" If you can find out whats done to the suspension that would be great so we could help you from that point, also cam and crank? Don't understand why he would replace either of those, see if you can ask him what cam it has, and more on why he changed the crank? good luck,
1998 gt
timing is a definite plus... and if u can get nitto 555 tires or drag radials. putting power to the ground is important
vortech v1 strim intercooled with lots of goodies , 4.10s, built rear end, pi intake, 78mm bbk tb, SCT tuner, bassani with flowmaster 44, mega bite jr lca, J@M full length subframe connectors, tuned by AED. and more suspension mods
2003 Mustang Gt
Slow
yea u hear alot about CUSTOM blah blah or racing this or that, look up what control arms are and see if it has upper and lowers or subframe connectors or coilovers or bump steer kit. while down there check to see if u have an aluminum driveline and a upgraded differential cover with maybe bigger axles. check for leaks and the bolts for ur lower control arms, mine snapped in half yesterday scared the shit outta me. and check ur ujoints cheap fix and important.
u said ur dads a mecanic and stuff so flush your trans fluid, radiator fluid, run good synthetics (motocraft,mobile 1,amsoil,royal purple) for motor oil. get a new oil filter (preferably Wix but others work) change differential fluid and add i lil bit of friction modifier to it.
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi |
Threads Similar to: 94 Mustang GT im new and was looking for help on building my car
| Car Building Feud With My Uncle | DrYCeLL2005GT | 2005 - 2010 | 62 | January 11th, 2010 09:20 PM |
| mild building my car | SWEET2KSTANG | 99-04 | 19 | May 24th, 2008 07:43 AM |
| anyone into car models and building them? | Drgnracin72 | The Clubhouse | 26 | March 1st, 2008 11:53 AM |
| Need Help Building a Plan for Race Car | Thewolfman456 | 5.0 Mustangs | 51 | November 3rd, 2007 09:06 PM |
| Documentry Of Building A Car | Bill | The Clubhouse | 5 | October 16th, 2006 02:19 PM |
