'95 Mustang GT Mods list. What do you think? - Forums at Modded Mustangs
post #1 of 141 Old November 18th, 2010, 10:31 PM Thread Starter
That Regular Guy
TerminalIntelligence's Avatar
Question '95 Mustang GT Mods list. What do you think?
Hey everybody I own an '95 Mustang GT and was thinking of putting a couple new MODS on soon. But before I do that, I'd like a little imput from everyone out there on what you guys/girls think.
Here is a list of MODS in order of how I wanna put them on: SLP LM1 cat back, bassani X pype, Professional products polished Intake manifold, 65mm throttle body and throttle elbow, also BBK headers, 3:73 gears, 2003 black cobra deep dished rims, 315's in back and 245's in front.
tell me what you think. Thanks!
Originally Posted by 4.6DreameR View Post
I would hit it like the fist of an angry God!
Originally Posted by cotton View Post
just wasted my whole night on this thread
Originally Posted by HurrycaneStang View Post
Wait till you waste your entire life on this forum...
2.8 pulley, steeda air filter, aermotive fuel rail, steeda tri-ax, and borla stingers.
TerminalIntelligence is offline
post #2 of 141 Old November 18th, 2010, 11:21 PM
hotmustang95's Avatar
I'm nervous when it comes to Pro Products intakes. I've heard bad things like leaks and not aligning correctly. Everything else looks good.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
hotmustang95 is offline
post #3 of 141 Old November 18th, 2010, 11:24 PM Thread Starter
That Regular Guy
What do you think about Edelbrock? My friend has an intake from them, but it only supports 300hp. I'd like a really good edelbrock if I bought one from them.
post #4 of 141 Old November 19th, 2010, 08:28 AM
What do you plan on doin with the car in the future? I would go with a bigger TB. Don't really know anything about that intake so... And as far as the 315's in the rear, if i'm not mistaken you have to remove the quad shock in order to fit those. But worth it IMO.
Dart Iron Eagle block & Pro 1 heads
DSS 347
80lb injectors
D1-SC
blueovalindustries headers
BBK o/r X
Flowmaster cat-back
3.73 gears
95Pony is offline
post #5 of 141 Old November 19th, 2010, 10:08 AM Thread Starter
That Regular Guy
I'm planning on a supercharger, but in a year or two, so would a 70mm be a better idea? And also, the rear tires, i head you could just slap em on, but if their bigger than 315 you have to remove it.
post #6 of 141 Old November 19th, 2010, 10:31 AM
Resident Headbanger
Bullitt95's Avatar
Since you're planning on adding a supercharger later on, I suggest you do the exhaust mods (headers, midpipe, catbacks) first. The items you've chosen will do just fine.
I also suggest that you keep the intake stock until you decide to add the supercharger. Then you can bolt on heads/cam/intake manifold/throttle body/MAF/supercharger all at once and save yourself a bundle of cash. This will give you a year to shop around for the parts and you'll find many of them cheaply in ebay. Decide what your goal is (HP and performance) so we can guide you.
As for rear tires, 315's would be too wide with deep dished rims and I think 275's would be a better option.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is online now
post #7 of 141 Old November 19th, 2010, 10:37 AM Thread Starter
That Regular Guy
Well the tires, 315 are recommended to fit these rims. But I have no problem going a little lower.
So start with the exhaust, and when I'm getting closer to getting the supercharger, start upgrading the engine is what your saying?
What if I want some more horse power before I'm looking at a supercharger? I only have 230hp which is a lot, but I'd like a little more kick to it. What could I do to add some more without breaking the bank?
post #8 of 141 Old November 19th, 2010, 10:58 AM
Resident Headbanger
Bullitt95's Avatar
You could save up for the heads/cam/intake manifold/75mm TB and do those before the supercharger. You'll also need a 255lph fuel pump and oversize injectors. I'd suggest 42lb injectors so you have enough room to grow for the supercharger and have the engine dyno tuned.
Since you'll still have the stock engine block, I recommend that you don't go higher than 8psi of boost. With the other engine upgrades you could have 300+rwhp and an 8psi Vortech could push it up to 450rwhp, which is as high as you should go 'cause it'll be getting close to block-splitting territory.
post #9 of 141 Old November 19th, 2010, 11:07 AM Thread Starter
That Regular Guy
I was planning on a KB super charger, it will have 8-10psi. I would change the TB once the airflow is starting to get stronger, and the engine will actually need it cause I don't want it if i don't need it, because i could damage the engine. The cams I'm looking at are the E303 cam. I've heard it a great cam. Latemodelresto, has a deal on a new intake, TB, and a shoulder piece for 700 that i was thinking of buying. But since the exhaust seems more important for the time being I'll go with that.
What all would I have to replace to get The engine to handle more psi?
post #10 of 141 Old November 19th, 2010, 11:19 AM
Resident Headbanger
Bullitt95's Avatar
Mmmm. That'll be pushing the stock block to the limit if not beyond.
Not for a supercharged application. If you're going to use a letter cam at all the F303 is the best option. Otherwise I'd suggest either the CompCams XE270HR-14 or the Steeda 19. Even the stock cam would be good.
The block.
post #11 of 141 Old November 19th, 2010, 12:08 PM
315's fit fine on those 10.5" deep dish rims. In fact if I'm correct, thats the recommended size for them. You can go lower or higher in size but the 315's are the sweet spot. The quad shocks should be turned around anyways since you'll be able to do it while your changing the tires. Some cars have the tire touch the quad and others don't so do it anyways. Every tire size is different from different companies. I run the 315 in the rear of my car on the same 10.5" rims.
P.B.M.C. Member
Track Addict
post #12 of 141 Old November 19th, 2010, 12:31 PM Thread Starter
That Regular Guy
Yeah, That's what I thought. So I'll just stick with that, what tires do you use?
So since the KB might be pushing it to or over the limits, what supercharger would you recommend?
post #13 of 141 Old November 20th, 2010, 07:07 AM
Resident Headbanger
Bullitt95's Avatar
6-8psi Vortech
post #14 of 141 Old November 20th, 2010, 08:39 AM
95opal's Avatar
Throw the gears in ASAP they will give you immediate gradification. Then add the exhaust and after that work on the engine combo. Bolting a throttle boddy to a stock headed car is a waist of time and money. If your dead set on a KB then dont shop for an intake now. As for the rims and tires thats your choice the 315s in the rear will look sweet but I would go biggier than 245 upfront like a 265.
95opal is offline
post #15 of 141 Old November 20th, 2010, 08:41 AM
Mustang Boy's Avatar
Send a message via AIM to Mustang Boy Send a message via MSN to Mustang Boy Send a message via Yahoo to Mustang Boy
Cool
yes like said above the 315s will not be an issue you will either have to remove the quad shock or just flip it over, i have 315s on the back of mine and i just removed the quad shocks cause mine were bad anyways and werent doing anything.
315's Crew
Black and White Crew
Crew Member #2
Mustang Boy is offline
post #16 of 141 Old November 20th, 2010, 12:28 PM Thread Starter
That Regular Guy
Alright, sounds reasonable. Well thank you guys, I'll keep you guys posted on how the project goes in the next few months/year!
post #17 of 141 Old November 20th, 2010, 01:55 PM
roast&toastEM's Avatar
315's are fine for that wheel size. i have deep dish fr500s with 315's. all i had to do was remove the quad shock. it barely rubbed. but since i dumped the quad shocks, i added better upper and lower control arms for supporting mods.
what part of nebraska r u in?
1994 Mustang 5.0
roast&toastEM is offline
post #18 of 141 Old November 20th, 2010, 08:54 PM
[QUOTE=SNmustang95;3316338]Yeah, That's what I thought. So I'll just stick with that, what tires do you use?
QUOTE]
Sumitomo HTR Z 11 for street but they don't make 315 for this model but they do for the HTR Z which I normally use but found my current 275's htrz11's for a hell of a deal. Their cheap tire's (price wise) and good for wet and dry. You can find them on Ebay new for real cheap or just get them from Tire Rack.
P.B.M.C. Member
Track Addict
post #19 of 141 Old November 21st, 2010, 12:51 AM Thread Starter
That Regular Guy
Lincoln.!
post #20 of 141 Old November 21st, 2010, 01:09 AM
Resident Headbanger
Bullitt95's Avatar
Does the outer wall of the tire protrude outside the fender arch? A pic of your ride would be nice so we can see how the 315's look on it.
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/192738-95-mustang-gt-mods-list-what-do-you-think.html
'95 Mustang GT Mods list. What do you think? This thread Refback October 8th, 2012 01:55 AM
'95 Mustang GT Mods list. What do you think? This thread Refback May 12th, 2011 04:16 PM
